Looks like i've got the last set of IE cams in the world not installed in anything
James, mine are the CVA1's which are the most aggresive Hydro one's, lumpy V8 idle etc
I heard rumours around April for the restock of cams. Bill may know better as he's after a set.
Piper also do a performance cam set for the 1.8t, also catcams.... There's loads of catcams varients though, dunno which version would work bet with your setup. Maybe have a look over on vwvortex mate.
cams like badgerwagen runs have been good for me. not as wild as IE's CVA1's but they are at least available, as are some other specials I have had commissioned.
old tread comparaison catcams
http://www.dubsinthebuff.com/forum/showthread.php?18755-1-8t-Cat-Cams-comparison-GOOD-INFO
catcams uk sold cam witch fixing timing:
https://www.facebook.com/groups/120128378000662/permalink/400502503296580/
and catcams installation:
https://sites.google.com/site/catcamsinstallation/
I'd ideally like the IE one's but I might have to settle for my next choice should they not be available in time.
What are your recomendations for my install Bill?
if lumpy idle is'nt an issue the aggressive ones, else the badgerwagen ones.
both made by catcams to specs I provided...
IE have no cams in stock
I can supply catcams to badgerwagen spec and others which are more aggressive.
I run chilled cast cams myself... I dont see the need for billets on hydro top end
lol - cake and eat it
I cant give xyz gains for badgerwagen cams as they were fitted with a bunch of other things.... and on a 1900cc not 2008cc motor....
they wont choke top end however like stockers do.. my peak power is at peak rpm and still climbing 8800rpm
Someone say track days
Glad you're putting the car back on the road sooner than planned. I thought you might start to miss the boost a bit
Update:
No doubt there will be more additions to the list before long.
Gear based boost control = No need Saving £££££
