The SEM's are a nice bit of kit. It's just a shame about the casting issues they have had. I hope they learn from their lessons and don't ship any out without pressure testing them.
Tim why don't you buy another run about so you can get the build underway?
Also, don't suppose you have got the diagrams for your battery box?
Hopefully the one Graham has was from after the casting issues were sorted, but you'd expect them to xray each item anyway
Unfortunately i havent ordered the bits for the head yet so until i get on that its held up abit
I can get the dimensions for the box if you want mate, however when i replaced my battery i found it was 15mm lower than meant to be as OE spec. So if you want the top like mine you may have to adjust for this
Ok, i'll get some measurements tomorrow for you
I still need to order everything for the head, going stay with hydraulic lifters for now too
Just had to pay my car insurance too so will have to put it off a little longer, maybe pimp myself out for some extra cash![]()
I picked up a largeport AEB a while ago so will rebuild that
I was going to go +1mm on all valves maybe help it make that extra horse or 2
I can always go solid at a later date if i choose to make it rev happy
Also i think you're right on the pimping, i dont want pocket change
Well had a chat to graham yesterday and i will be buying his SEM which should be from the batch after the porous issues and ok
On a side note Bill, do you carry the 330mm rotors in stock as my ones are very low now and will need to be replaced but need some tyres first, just incase i need to plan lead time
