nightflight
Mk5 Ibiza Bulb List
Pander
139
Corby.
www.facebook.com
Good info on here ! One thing that annoys me is the arse that coined the phrase CANBUS lights, it doesn't even have to have CAN system to know when lights are not working.
vmark89
Mark Brown
Sep 10, 2012
211
17
Ellesmere Port, Cheshire
Hey guys just thought I would see if someone would kind enough to post this onto the main front page :)
The Facelift Model FR only has 1x sidelight on each side apposed to the 2x on older variants but still remains a W5W 501 unsure if it requires Can bus as I'm using Ultra Bulbs in them Currently.
Dipped and Main Beam Bulbs remain the same as H7's
The Fog's are different though :( there not H11 as the manual says and there not HB4's either as Seat tried to fit them when I collected the car and they are now HB3 as far as the service and parts manager was conserned.
KippeRFR
Please Make Sure To Correct
FACELIFT FOGLIGHTS Use: H8 / H11
HB4 Doesnt Fit :] (Had To Order Twice Because Of That Mistake :))
abristow
68
Cyprus
Does the cupra require canbus dipped beams? Because I have the H7 HID kit out of my mk4 but they are non canbus
Alex
Yes mate I believe they have to be canbus but try it I believe each ibiza is different. I bought 2 bulbs for my reverse light so I put on 1 and I gave the other one to a friend who has a bocanegra. It works fine on mine but on his it flashes all day long... :wtf:
nightflight
2,677
12
Sheffield
OK, now I can edit the first post.
There seems to be some disagreement on the facelift fogs..
KippeRFR says the facelift fogs are H8 / H11
vmark89 says the facelift fogs are not H11 and are HB4
Anyone able to comment further?
nightflight
2,677
12
Sheffield
This should read as below..
vmark89 says the facelift fogs are not H11 and are HB3 (not HB4 as originally stated)
If KippeRFR and vmark89 could confirm which models they own it may be down to difference in models as per the 3 and 5dr versions having different reverse lights.
KippeRFR
I Own the Facelift 3dr!
Foglight bulbs are defintly H8! (H11 Also Doesnt Fit :\
