Dan's GTX3582r, 2.0 20v, project '600'
Dan1720v
1,928
Street, Somerset
So, unfortunatly, still no real updates on this. I have bought this turbo manifold from Sam Bryant, so its a step closer, just been so busy with customers cars its unreal :(
worzel
LCR 225
Dec 20, 2009
366
Jersey
Hi Dan, a quick question re this pic of your diff
What are those bolts, as I need to order some for my exact same diff?
I also wondered if you could recommend some decent rear ARB drop links.
Chris
Dan1720v
1,928
Street, Somerset
Hi Chris,
Yes they're the ring gear bolts, as the OEM one is Riveted on. You can order the Diff and Bolts from TSR. If you let them know Dan the renault specialist sent you they'll sort you out ;)
air121005
1,609
Worcestershire
only just spotted this thread:confused:
anyway....epic build!!!! :clap:
admire the level of detail to the technical side of things, great work!!!
...and others have said.....that turbo's feckin huuuuge!!!! :-o
worzel
LCR 225
Dec 20, 2009
366
Jersey
Hi Chris,
Great thanks been in touch with them.
Chris
Dan1720v
1,928
Street, Somerset
Thanks mate,
Nah, Leon was stripped for spares. Still have the engine and box however, they're sat in my clio now :) just need a few free evenings to get it finished. And trying to decide what blower to mount.
Dan1720v
1,928
Street, Somerset
After a few people have asked...
So here is the story of my grey ph1.
Purchased back in 2013, in exchange for my horrendous A3 3.2. It was back in my type of car.
Spec then was
Jenvey 48's
Piper cross filter
428 cams
Arp big end bolts
Ktec super sports exhaust with decat
But sadly this engine had been cooked on the dyno by TDF, and it was apparent all was not well with it (using a lot of oil and smoking quite a bit) at this point a supercharger kit came up for sale with a knackered charger. A deal was done and I was then on the lookout for a new charger, one popped up on eBay and I bought it.
I then had an engine provided with the car that I dropped in at the same time as doing the supercharger conversion. Sadly this engine was also no good, after 100 miles it had used as much oil as the last one so it came apart. This then showed 2 pistons with cracked ringlands. 2 new pistons in and away we went.
Did all my mapping on the road with a friend, which spent several evenings like this:
With 500 miles on the clock of the new engine it was down to the south west rolling road day where it made:
Not bad!
Slowly I kept grinding out the restrictor to give more boost.
A few track days thrown in for good measure..
Then on a meet the supercharger started making some peculiar noises. Back to base found that it had pumped all it's oil to the reservoir, but not drawn any in. That's the end of that then.
So I then did this.
And a bit more.
Which resulted in this
Few evenings of this
Along with a few other bits:
Quaife diff
Resulted in this:
A days mapping with chip...
I was caught off guard here.. This is the "oh you're taking a picture" face.
Quite compressed, but that's the run down of it.
Dan1720v
1,928
Street, Somerset
Finally the spec is:
Ph1 172
Exterior
Porsche grey black paint
Poly carb windows
Carbon bonnet
Cup spoiler
Interior
Stripped out,
Flocked dash
Clock console replaced with Wideband lambda, boost and EGT gauges
Snap off steering wheel
Safety devices roll cage
EPAS Conversion
Cobra evolutions with Renaultsport embroided
Engine/gearbox
1.8 20vt
Fully forged (crank, rods, pistons)
Stock inlet with ph1 172 throttle body
Custom Tubular exhaust manifold by SAS Welding services with top mounted GT3071r turbo with 4" inlet.
Magnecore leads with 172 coil pack
Specialist components typhoon 2 ecu
Siemens DEKA 630cc injectors
Run on Fuchs Titan pro-race oil
Custom mounts
Zircotec protected engine bay
Heat wrapped and ceramic coated downpipe
300x600x76 intercooler painted black with black hosing (stealthy)
Fancy features mapped in like boost by gear control, closed loop boost control, launch control. Mapped by SJM Automotive.
02M gearbox with Quaife LSD
Hydraulic clutch conversion
Single mass flywheel
Custom driveshafts by GB Engineering
Fuel system
4bar fuel pressure regulator
Walbro 255lph fuel pump as a lift pump
Bosch 044 main pump in-line
Suspension
Bilstein b14 coilovers
Pure-Motorsport top mounts
Pure Motorsport rear anti-roll bar
Roll centre adjustment kit
25mm front spacers
10mm rear spacer with 2 degrees neg camber
Brakes
300mm front discs
Wilwood calipers
Ds1.11 pads
Super blue fluid
Braided lines
Wheels/tyres
Road wheels
OZ F1 with Michelin PE2's in 195/50/15
Track wheels
Dry:
Pro race 1.2 with NS2-R tyres in 205/50/15
Wet:
Speedline 2118 with Michelin Pilotsport 3 195/50/15
Dan1720v
1,928
Street, Somerset
Me too! Had a little play with a 13 reg M5 on the way home the other night. To cut a long story short, he couldn't keep up :lol:
Pulled up beside me at a set of traffic lights and shouted across "what the **** is in that?!" Haha!
