Update folks.
Everything was set out for Revo stage 2+.
Unfortunatly on installation the downpipe did not fit properly as it was designed for the S3
However, the induction kit, high pressure fuel pump and RS4 valve were fitted as well as the the oil change and pollen filter change with gearbox oil change as well
I then got a brand new software update of the REVO stage 1 map and we went out to log the car. While logging there was enough head room with the new mods to adjust the timing to 6, te boost to 7 and the fuelling to 7.
This was then called the stage 1+
The car should be running approximatly 330-340bhp and 330-340 lbs ft torque. And what a difference so much more powerful through the mid and top range, when changing gear it just pulls harder. Really impressed with the set up
Here's a few pics taken:-
Next mods up over he next few months will hopefully be.
Full Milltek system, limited slip differential, uprated clutch, WALK kit and stage 2 +
