WeeG Stage 3 APR Leon Cupra R mk2 TFSI (Banana) 436.5bhp 438.2lbs/ft torque
AndrewJB
Aug 16, 2007
11,209
485
Maranello
Haha i was going to get one of these the other week but decided to save money at moment got a busy month
Il be up your way Next Friday till monday mate
WeeG
3,407
Largs , Ayrshire
All going well it may be Revo stage 2+ on Friday sports cat and dp, Hpfp, induction kit and RS4 valve :) with oil change, gear box oil change, pollen filter change and REVO's new 2+ software to approximately 360bhp :)
Al
7,331
9
Just need to learn how to drive it at that point ya soap dodger ;)
Oh, and you have 14.3 to beat :lol:
WeeG
3,407
Largs , Ayrshire
Update folks.
Everything was set out for Revo stage 2+.
Unfortunatly on installation the downpipe did not fit properly as it was designed for the S3
However, the induction kit, high pressure fuel pump and RS4 valve were fitted as well as the the oil change and pollen filter change with gearbox oil change as well :)
I then got a brand new software update of the REVO stage 1 map and we went out to log the car. While logging there was enough head room with the new mods to adjust the timing to 6, te boost to 7 and the fuelling to 7.
This was then called the stage 1+ :p
The car should be running approximatly 330-340bhp and 330-340 lbs ft torque. And what a difference so much more powerful through the mid and top range, when changing gear it just pulls harder. Really impressed with the set up :)
Here's a few pics taken:-
Next mods up over he next few months will hopefully be.
Full Milltek system, limited slip differential, uprated clutch, WALK kit and stage 2 +
van cleef
Been really glued to this thread just a pity about some parts ie the arguing.
love the car by the way!I'm watching in interest if this quest for power will corrupt. :)
After picking my R a couple of weeks ago it's giving me some inspiration to up the performance in mine and I Wouldn't mind a butchers in the flesh to compare standard to modified.
Al
7,331
9
There's one a lot closer to you if you want a look :)
WeeG
3,407
Largs , Ayrshire
The cupra R is a quick standard car. You will be shocked with the difference:D
Squealy
99
Northern Ireland
Loving this thread but i am baffled by the power figures for the mods that have been installed... maybe its just me or it could be the whole 'Dyno Lottery' thing... but my Cupra on a stage one map with an intake and it produced 328.5BHP and 314.3lb/ft of torque. Hopefully a pump, dp and de cat will see around 360+
kilner
326
i think its the usuall dyno lottery look how many pd170 drivers thort they had over 235bhp and that is proved to be 100% wrong
Squealy
99
Northern Ireland
That was my exact thoughts. Need to get it on other RR's to get a guesstimateat possible power being produced. BIGG's Cupra R is unreal though! need to own :)
kilner
326
dyno dynamics are a good set to go with the they almost give the same readings at any place in the country
