I have read more now (almost every page) and see that most of you recommend butyl for seal.
question 6 or 10mm?
Can I order butyl from my vag dealer?
in that case, anyone has the part numbers? (butyl and door clips)
they should be able to find the door clips with my licence plate but the butyl i doubt they know what it is. :-(
must say I wonder if my LCR 2004 has the butyl seal already or when did seat change to that?
My LCR is a 54 reg and doesn't leak I'm even with the recent downpours. However I reckon a previous owner may have done them as I'm never normally that lucky with cars that I should have one that doesn't leak in. My last LCR on a 54 was terrible. In fact, there were 'pairs' of various animals in the footwells
I did my drivers side some time ago, and while it's all dried out, I still get water close to kickplate sometimes when I open the drivers door. Heres my findings. Park the car on a level surface, no build up either side. Park the car out side my house, passenger side into the kerb which is a fair slant, there will be a build up on the drivers side, much less than previous mind but still there. Park the car the other way round so the drivers side is in to the kerb, and there will be no build up anywhere. So I think it's partly down to main door seal too. Drivers side being the most used throughout its life. I might see about replacing that too if I ever get wet carpets again.I did my door seals last year, and recently im finding water so close to entering the footwell just like it did before i did the seals. Have i done something wrong??
todays progress:
as it stopped raining for 30 minutes today i thought i would attempt the leaky door fix now my stuff has arrived from ebay, i thought it would only be a 30 minute job but i took the door card off and was greated by this monstrosity
im sure its not standard to have that much soundproofing, its all inside the doors as well, the panel was also bodged back in place with what i can only think of as pollyfiller covered with silicon sealant
i found out that the speaker is an aftermarket alpine one that has been stuck on a plastic bag, then stuck on a adapter then stuck on the soundproofing then screwed in to the existing speaker holes
even the tweeter is bodged, im sure its not supposed to look like that, and the cables are all bodged as well
i have removed as much of the bloody pollyfiller and sealant as i could get at and have replaced it with butyl sealant strip, then i removed the speaker adapter and cleaned all the crap off that and removed some of the soundproofing it was sitting on and stuck it back on with butyl strip and screws.
i think the water was getting in through the soundproofing the speaker adapter was sitting on as half way through cleaning the crap off it started raining again (so it was a mad dash to get the gf's parents garage clear to get the car in there) and all around the bottom of the adapter was wet.
at the moment its all put pack together hopefully properly, but i have masking taped up the window tonight so it has a chance to seal properly, i will take it of tomorrow and it will hopefully be nice and dry on my door seal and carpet after tomorrows almost certain rain.
can anyone help me out ive did all my door seals and the water is still laying in the sils when you open the door its getting up over the seals at the door and going into the footwells....i dnt know how the water is getting there as the sides of the door is dry but under the door is wet and so is the bottom of the door cards??
