Currently half way through my GTI Inters prep!
Detailed the engine bay today and prep'd all the paintwork ready for the polishing tomorrow and a few layers of Zymol Glasur!!
Also fitted:
-Silver mirrored indicator bulbs all round, including the side indicators, to hide the nasty amber glow.
-Side indicator tinted lens's
-Painted engine cover insert candy white
- Repainted the lower lip gloss black as it was getting a little tatty.
I also made a mini
guide on
how to change the oil on the 2.0 tsi engine incase anyone wants to tackle it themselves ( really easy on these engines)
1.Open the oil cap at the top to stop a vacuum when the oil is draining.
2. Remove engine cover ( Just pulls off)
2. 19mm socket is needed to crack off the sump plug and washer ( Be careful when the oil gushes out, wear glasses etc etc. ) Get ready to catch it with your oil pan or bucket! Tip- Take the car for a good 10 min drive before hand to get the oil really hot, as it drains a lot quicker when it is hot and more of it will drain out too!
3. Remove the old oil filter if you are changing it. ( It shouldnt be tight, mine twisted off by hand)
4. Replace the sump plug with a brand new one and washer.
5. Put a new oil filter in ( Lube the seal with a little bit of oil )
6. Refil with an oil of your choice, I went with castrol edge ( The TSI takes 4.9 L )
I put in about 4.5l, then started the engine and left it running for 5 minutes. Then turn it off and top up the oil as required.
Tinted side indicators:
Silver indicator bulb on the left:
Before:
After:
Much cleaner look!
Detailed bay with freshly painted engine cover, and hard plastic battery box instead of cloth cover:
More pics to follow of the full detail tomorrow!
