a sick PD150 ?
Sep 18, 2009
2,443
Shropshire
My Leon FR PD150 is suffering from man flu i think.
Just after i did an oil and filter change my car started to sound really poor. Ive put in the right amount of oil and the correct grade, so dont know if this is just a coincident.
The car sounds louder and with less power. getting a "bap bap bap" sound on idle and through the rev range, like a crappy version of a subaru on idle.
sometimes it clears itself and its ok, but then it comes back again. Also seem to be getting vibration through the steering wheel at higher speeds when its making this sound.
Could it be a gearbox or engine mount ?, the cambelt slipped a tooth ? a dying turbo ? another boost leak ?
Any ideas ?
2,443
Shropshire
Check all your boost pipes firstly
yer might have to. Getting sick and tired of this boost pipes. even upgraded the pancake pipe and hoses with an SFS item and managed to even blow the hose off that once and then again from the turbo end. Might as a precaution order some new green grooved boost seal rings.
Sep 18, 2009
2,443
Shropshire
That sounds like its a cylinder down.
i also thought that like its firing on 3 cylinders ?
Check the fault codes.
i did and vag.com is finding nothing ?
My moneys on worn camshaft / hydrualic lifters
My pd160 did the same. Had to replace camshaft, tappets, followers and tandem pump :(
if thats the case whats the sort of cost, and i wont be doing this myself so ill be looking at labour costs on top. If this was the fault, would it come and go though ? although it doesnt appear to be going anymore ?
SlimLCR
185
Lincoln
My golf pd150 sounded the same when the tapet went. Stop running it until you can get the head off and check. I ended up having to replace the head too :(
Sep 18, 2009
2,443
Shropshire
At what sort of cost if you don't mind me asking ?
Could this be an opportunity for any performance upgrade ?
SlimLCR
185
Lincoln
Hmm it was a about 12-1300 I think, it was a few years ago but I had the work done at a local vw specialist. VW wanted over 3500.
Mine was pretty bad, the tapped had snapped and the mashed against the head, damaging that. Luckily it didn't damage the piston.
I ended up with new head, tapet, camshaft, Cam belt and water pump, plus glow plugs and labour.
Sep 18, 2009
2,443
Shropshire
Bloody hell :blink:
Just had new glow plugs, cambelt and water pump aswell :cry:
Well that's it then, iam gonna retire it and maybe take it to p-torque as there only about 20 miles from me.
AshFR
Seat Leon TDi PD150 2005
Mar 10, 2011
385
Shropshire
photobucket.com
Ahhh ****. Bad news mate :( mind you it has done a good few miles but nothing for a diesel i know. I will come up soon buddy so you have a feel of the remap :)
Sep 18, 2009
2,443
Shropshire
Hi ash, yer come up dude so I can feel what nearly 200bhp feels like. Mines feeling like about 100bhp now :cry:
Iam on 153,000 miles now.
lawrieIbizaMk4
Team Boc!
Aug 31, 2009
3,541
Milngavie, Glasgow
www.bebo.com
12-1300 is what it cost me, if the tandem pump is gone make sure you have relevant oil and filter changes done again as there will be a bit of diesel in the sump. I had mine done with a kolbenschmidt uprated cam, think it was about 150 more expensive
Sep 18, 2009
2,443
Shropshire
Was the uprated cam a performance gain ?
lawrieIbizaMk4
Team Boc!
Aug 31, 2009
3,541
Milngavie, Glasgow
www.bebo.com
Not sure, I only ordered it to ensure it wouldn't happen again any time soon, it's made from stainless steel iirc instead of the cast kit tat comes standard. Would imagine it could take a bit more of a beating than the original parts.
I sold it 2 weeks after though as I was sick of chucking money at it
Sep 18, 2009
2,443
Shropshire
Iam gonna see if I can take it somewhere today..........let the engine rebuild begin :)
Iam gonna strip this bitch and replace with new :)
