Dat kyid's cupra r 210 (bumblebee)
mcdatkyid
Hey everyone!
finally reached full membership so decided to post up a readers ride of my leon cupra r 210 in ovni yellow (bumblebee) ha ha.
Il go from first things done to present!!
Hope you like and feedback would be greatly appreciated :D
I bought the car in may 2011 for a nice deal i think 3700 sterling with just under 90k on the clock, full servive history, stage 1 remap 250bhp), all recaro interior and a massive smile on my face!!
First port of call was a service and maintenence check so booked it in to be serviced next day! Just to make sure everything was in order and to know it was now my car!
I then had to by no means necessary had to fit my sound system because no bass brings a sad face!
I order the facia adapter and then installed my Sony X-Plod headunit, 1200w X-plod subwoofer and Fusion 800W Amp. It was a struggle to get the cables through from the engine bay to the inside of the car but after an hour or so manged to wire it up all nice and hidden!
The next thing i fancied was to add a little bit of viynl, so opted to viynl wrap the bonnet , roof and rear spoiler, wing mirrors and door coloumbs.
Shot at 2012-03-11
Shot at 2012-03-11
Shot at 2012-03-11
After looking around on this forum to see what people have been doing to their LCR's , so started on a few little things.
Seen alot of them were lowered and looked mean so ordered some Pro Sport Coilovers for 260BHP and had them fitted 20/6/11 by my pal in our local styling garage cheap as chips at 20GBP a corner. Took it for a spin and held the road alot better and felt more stable only thing is when reversing out of the garage i got grounded (ooops!) a little to low. Living in tamworth the streets are notorious for speedbumps and potholes so raised it up alittle so not to damage the underside or sump! While having this i had my powerflex dog bone mount bushings fitted to try help with my wheel hop.
Shot at 2012-03-11
Shot at 2012-03-11
Just to show how low i went in comparrison with my iphone!
Got a few visual mods around june for my car to suit me. So i ordered a 3rd break light cover, fabia rear wiper, front aero wipers, bee sting arial adhesive remover to debadge all the standard lettering and some transformers self adhesives (hence the name bumblebee).
Shot at 2012-03-11
Shot at 2012-03-11
Shot at 2012-03-11
I ordered more for my car end of june when payday came around including my forge yellow upper turbo pipes, Forge 007p Recirc valve, silicon 3mm & 4mm hosing and a pipe joiner.
The upper turbo pipes took around 3 weeks to deliver but was happy with how they looked after. Also while fitting the turbo pipes i did the common N249 bypass which made a great difference.
Shot at 2012-03-11
I then drilled my air box to allow a little more air in which made a slight deeper grunt under acceleration. Very easy to do to and cheap :funk:!
Also purchased an SFS Turbo intake pipe which i am yet to fit so that will be the next part fitted.
I left modding for a while and made do with how my car was until this month and bought a few little things.
Some Wheel viynl for 6.95GBP
Shot at 2012-03-11
Shot at 2012-03-11
I started a little bit of interior visual mods to jus to make a little change. Cost 4.93GBP and just finished it this morning.
Shot at 2012-03-11
I managed to buy a boost gauge off a friend who wrote his cupra off last week for 15GBP so that was a bonus and fitted that the start of march. It shows im boosting 18psi!!
Shot at 2012-03-11
I seen a post on here for the TRS tow strap too and thought it would be a nice addition as im after removing the reg plate holder and meshing the front bumper up and relocating my plate.
Shot at 2012-03-11
This is my progress so far! Hope everyone likes my ride.
Shot at 2012-03-11
Shot at 2012-03-11
Shot at 2012-03-11
Shot at 2012-03-11
Very Appropriate name for my car even the bumblebee likes it :lol: !!
Here are a few things i want to do:
  • Relocate Reg Plates
  • Replace turbo back exhaust
  • Decat Exhaust
  • HID conversion
  • Fit 3'' TIP
  • Front Mount Intercooler
  • Recondition Brake calipers
  • dyno run once everything is done
  • Mesh Front Grill
  • 15mm Rear and 10mm Front Wheel Spacer Kit
  • Fit 323mm Front Discs
  • Mopping
  • De lock front door
  • Smooth boot with open catch inside
  • Steam Clean Engine Bay
  • Valet Inside & Out
i will update as i go on with future mods!
thanks for passing by to my thread!
IF YOU GET THE CHANCE PLEASE CHECK OUT MY WEBSITE FOR FREE MUSIC FOR YOU TO DOWNLOAD AND ROCK IN YOUR RIDES FREE TO ALL THE SEATCUPRA.NET GANG!
WWW.DATKYID.COM
mcdatkyid
Got a few pics so will upload themtoday or during the week because I havn't finished it yet, I'm just in the middle of fitting a few trimmings !
mcdatkyid
Interior strips fitted today! pleased with the look could just do with a clean now while the sun is out!!
mcdatkyid
Readers ride update 25/3/12
Managed to get a chance to get a few more things done to the beast this week!!
As my downpipe had cracked i decided to just buy a new exhaust. I quoted 300GBP for a standard OE downpipe or 320GBP for powerflow :cry: So instead i hooked myself up on ebay and found a guy selling a straight through turbo back decat exhaust for 175GBP and had it fitted for 60GBP by a friend.
It sounds great and seems to give a little more power on accelaration and gives off a nice deep grumble low and mid range revs.
I also fitted my Samco TIP 23/3/12 and fitted a new air filter 21/3/12 to see any difference from the pipercross panel filter i have been using!
Shot at 2012-03-25
and then set out to remove the reg plate holder and remove the OE mesh from the front bumper and remesh it. It took way longer to install as i had to wait for the silicone to dry over night plus all the screws and bolts were ceased so now have blisters on my hands but was worthh the effort and time :rofl:
Shot at 2012-03-25
Also treated the car to a nice clean and shine to as the sun is out booomin!
Here are a few things left to do:
HID conversion
Mopping
De lock front door
Valet Inside & Out
Cupra Grant
111
Looks good Don't know about the transformers badges but each to there own. Nice to see the another cupra r in Tamworth there's not many around and I've never see yours lol I know what you mean about the state of Tamworth roads my splitter is wrecked. Because of the speed bumps
Deleted member 12147
Looking good, you should go for a smaller front plate though or a flip plate;)
Aug 5, 2010
825
Pig Hill
I have an OVNI (not onvi!) car too, always wondered what a CF bonnet looked like, looks kinda cool.
The reCarl interior has "recaro" written on it ;)
mcdatkyid
Will have to look into that! I just needed to fit the plate back on because it was a little hot with police! Been pulled twice with it inside the car!:whistle:
mcdatkyid
Yeah soon as I brought it I thought about the badges and had to ha ha!! Got any pics of yours? Is it black by any chance?
Cupra Grant
111
no its not black mate its a grey one my readers ride thread is about somewhere have a look may have to have a little photo shoot /mini meet
mcdatkyid
U don't live glascote road do ya? See one parked up just after the garage? Should be getting it topped this month and iv got a mate who's hot on the photography so will have to sort that out!!
Cupra Grant
111
Yeh sounds good to me I'm useless with a camera I don't live on the glascote road I Live in amington have seen another grey one with black wheels around what sort of power are you running ?
mcdatkyid
That's probly the one iv seen then man! Mines running around 250bhp but iv had a turbo back decay fitted so id like to get it on a dyno n check! You know anywhere mate?
Cupra Grant
111
Sounds good myns running 247 had it rolling roaded up at dyno days at Hinckley next door to r tech looked like a decent place and with r tech next door if anythings wrong with the car nick will help you out. Having myn possibly remapped to stage two by nick the run cost me 40 quid for 3 runs puls afr run to check the fuel air mixture
mcdatkyid
Cool will have to roll up there mate! Sounds like we are running around the same! Is yours the 210 or 225?
Cupra Grant
111
225 bam engine nick said its a cack map should be in the 270 area with the mods I was running at the time ive since added a tx intercooler kit
mcdatkyid
That's sound man!! what mods are you running mate? Try inbox me your readers ride!
