nice ride
car looks great mate, im loving the camera idea.
PM'd you dude.How did you fit a double din player in there? Its only a single din in the leon im getting. Or is it a custom job? If so, can you still get access to OBD2 port?
Im also after jetex red cone filter and jabbasport filter heatshield. Where did you get them from?
Also where abouts in Shropshire are you, im in Ludlow?
Thanks.
Thanks mateNice car that bud
30 psi is definitely over-boosting! These as standard are only meant to boost 21.7 psi!
It's not putting it in limp which such an over-boost?
red SFS TIP installed, pic also shows the Allard EGR delete kit.
Hi mate, which delete kit did you go for? and did you get a dash light come on after fitted?
I have looked at these but been put off by folk saying an EML comes on and needs mapped out & the anti shudder valve doesn't work properly.
Any info would be great cheers...............oh and nice motor thread there
Hi, i got the allard EGR delete kit from here
http://www.ebay.co.uk/itm/Allard-1-...arParts_SM&hash=item27c3677fe0#ht_1823wt_1163
Havent had any problems or lights come up. When i took off the EGR is was nearly solid with soot. Had alot less smoke since putting on the EGR kit. Happy with it so far and had it on for about 6 months or so now
nope still driving ok and no limp light. Just to eliminate the boost gauge being incorrect, i have a liquid leon gauge which also shows boosting to 30 psi.
Could this just be my the boost pipes down near the intercooler\pancake pipe, cause i know them clips that hold the pipes together are on there way out.
Wanted to change them all for some SFS red silicone ones anyway ?
no iam still on the stock map 150 bhpI suppose you are running 193bhp, I had forgotten that. If your pipes are on the way out or clips etc, I would imagine you would be suffering low boost due to boost leaks. Is there oil to be seen round them?
I would imagine the correct boost for your power would be about 28psi max, so maybe afterall you're not over boosting at all even.
I aint an expert as I'm running standard map still. But I know a lad with 180bhp and over 300ft lbs who's boosting to 27psi.
Nice looking car, i have a fr tdi but in grey. I have replaced the interior lights with led also, where did you get the bulbs for the rear head lining lights? As i cant seem to find them in that size.
Jack
