Lower+Handling+Comfort ??
Jun 23, 2011
627
Inverurie
as title says whats my best option to get the best of all 3
Low - i dont want to slam it just fill the arches a bit more. (+dont want the horrid back wheel pushing forward look)
the main thing i want is increased comfort + handling whats the best options (without spending over £500ish) to go springs/dampers? coilovers? springs?
im a novice at dealing with suspension mods so no idea whats good makes from some quick searchs , Weitec GT coilovers and KW V1's were the ones that came up however i dont know if this was best for lows or what etc
any help be great cheers :D
blackcupra180
514
fife
to be honest you wont get increased comfort from lowering as the lower you go the stiffer the springs are. I run coilovers (just cheap ones of ebay) which alot say stay clear of but i have no problems with and i have had them on for 3 years.
my cars on its arse but when it wasnt it was just lowered a bit with the coilovers and to me they were comfortable but when i had my mum in the car it was ooooo this is a bit harsh :rolleyes:
Jun 23, 2011
627
Inverurie
did think that , well mainly instead of improving comfort maybe i should have said to not lose much comfort :p haha ... mainly i just dont want to get some and not be happy with them haha
blackcupra180
514
fife
haha. Well i hardly use my car so comfort doesnt really matter to me but if i was doing alot of miles then it wouldnt be getting lowered. But am sure you can get top mounts which am sure lower 10-15mm without effecting comfort. (i think)
DamianPM
6,389
84
Newcastle/Durham
To be honest you'll struggle to increase comfort when lowering but from what you've said I'd personally say go for the KW springs and shocks kit or maybe some Bilstein dampers with Eibach springs.
Damian @ DPM Performance
Jun 23, 2011
627
Inverurie
if i throw comfort out the window , what would you recommend best for handling + slight lows ? (handling is def. the main improvment i want tbh :lol:)
Sep 4, 2009
736
I've been on standard, then 35 mm drop springs and now coilovers.
Standard definitely the most comfortable!
Spring kit, slight less comfort but not that noticeable, improved handling
Coilovers, quite a bit firmer, have to take time over speed bumps! But a massive improvement with handling.
You could just go for a small spring drop, then do ARB and bushes if you're after handling improvements
627
Inverurie
Within your budget I'd go for the Weitec coilovers.
cheers for the info, think the coilovers prob the best then as the springs im limited to what they provide in height and looking at them i need it higher at the back (i think)
well im on a cupra r so im already 25mm lower than standard and think mine comes with the front ARB , think i may go for coilovers then
Sep 4, 2009
736
I know that, but still spring kits available, just trying to accommodate for comfort.
Yes you do have a front ARB but you can get uprated ones and fitting a rear one makes a significant difference too.
Also see dolbys review on his car after he fitted a full set of super pro bushes, can make a massive difference.
http://www.seatcupra.net/forums/showthread.php?t=344561
627
Inverurie
yeh no worries cheers for the help like
ah right good point ill have to have a look to see whats the best the link you pposted is quick a good read tbh
only prob with them is dam its expensive XD haha
Deleted member 22032
Sorry to hijack the thread, but I'm buying some AP coilovers this week, will I have any problems with them fitting as towards my ARB's or up rating the ARB's in future?
Tommyboy91
Scooby's + Seat's
Jul 18, 2010
146
Inverurie
Im replacing my ARB bushes on my 01 1.4 leon at the moment, Fitted uprated powerflex ones. . Will see how they go in the long run..And other bushes/improvements i could make to the handling suspension wise without touching the struts and springs.
Will be fitting better/lower springs in a few months when budget and time allows.
Your local to me 24Sevenbiker. I work there..at "Spoons" Gordon Highlander. If you see a Silver leon kicking around Inver..Give me a wave
jase750
662
Stoke on Trent
Visit site
I went for Eibach pro kit springs becasue I was after pretty much everything you are and so far I'm really pleased, slightly lower improved dynamics and not too bad ride comfort.
Jun 23, 2011
627
Inverurie
how do you find the powerflex bushes? im either going for them or for superpro ones
ah cool , if i spot you ill give u a flash or wave mate :p , however im pretty bad at spotting someone , once my friend let me out of a junction .... didnt even know it was them :whistle:
the lows in your pic does look good how much does the eibach kit lower by??
Tommyboy91
Scooby's + Seat's
Jul 18, 2010
146
Inverurie
There okay at the moment..done 20 miles in them...seems a bit better up front, not so lazy for want of a better word.
Yeah ill give you a wave as well. Im always parked up by the swimming pool or just next to the legion for work. Got to medel with the exhaust again today:(
miscreant
131
I got a set of ap coilovers from damian just over a year ago didnt drop the car too much just wanted it to sit a little lower, i was very suprised at the comfort level of them didnt really feel any different from the standard ones, corners well aswell, also fitted a eibach uprated anti role bars front and rear, but took them off after 6 months and put the origional back on as they made the ride very harsh and didnt seem to make much of a difference in cornering on the road.
