Todays little project
Over the next couple of weeks I'll test fit it, seal it, spray it black and then wrap it in Carbon Fibre.
It's aim is not for aero but to protect the plastic splitter aswell as look good, hopfully !!!!!!
That's what I found with mine, when I put spacers on the front you could see the arch gap more. Probably why I hated my lowering springs so much and went for coilovers and dropped it properly.
You can run the car lower at the front even for daily use IF the splitter is off, it's how I am managing to get around without any hassle. I still haven't tested it with the splitter on so can't comment :shrug:
Wont the splitter just make the car more unusable Daz? Its going to add another 4-5mm to the lowness of the splitter which will cause problems surely?
It should'nt be too bad mate, I'm sort of building it to be wrecked, it's job is to protect the main spliter, once it's wraped it will be about 5mm thick, theres only 1 speed bump round here that I have problems with.
It will tho if you glue or screw it on. If you hit something hard it will rip off?
Hey buddy your car is looking amazing as always. Can't wait to see what the new splitter looks like. Just wondering did you get my pm the other day?
