Winter tyres
I'm running same pressures as summers.
I think there is a belief that you should run a few psi lower however (iirc) I think it was Lee who got in touch with a major tyre manufacturer or pulled it off their website advising to leave pressures as per normal (may be even Camskill).
Confirm either way please Lee :think:
My manual says run them 0.2 Bar higher.
RLyons
310
I think higher pressures are better, my fronts looks half flat with 34psi in them! Need more like 36psi or more.
Pretty disappointed with the winters generally too, currently wish I hadn't bothered. They are a bit more wallowy, much less grippy than summers above 0 degrees and weren't much better than summers in the snow.
Maybe I expected too much from them... I could also be proved wrong if the winter gets a bit sharper!
Tam
Santa in disguise :)
Feb 10, 2005
1,777
Near Reevo :)
gonna take mine off this weekend.... save em for next year
will just put em back on if it looks like snow will arrive in February... no snow forecast for January here :(
dalegolf215
UNbanned
Jun 3, 2010
1,151
Rov'rum
Still hovering between 3-8 degrees around here so mine will stay on until spring, plus we usually have our snow in january sometime anyway
air121005
1,609
Worcestershire
have cosidered taking them off but as the temps are between 0 & 5 most mornings , and as you say we usually have a spell of cold weather late jan / early feb.....i'm thinking the same TBH !
RLyons
310
I only got to test them out because I went in search of snow in the lake district! Barely seen below 0 all winter!
bubbles1
Nurburgring Lover
Dec 28, 2008
490
Llandudno
I'm off to Gleshee ski slopes in Scotland in a few weeks and i'll be bloomin miffed if i can't test my winter tyres out !!!!
Fishy
1,080
Looks like us southerns might get some use for them after all... :D
Fish
Fishy
1,080
Not yet here. :( Due around 5pm, just in time for my commute to work. :(
Fish
eta76
Flying dutchman
Jan 6, 2012
77
It's snowing in Holland. And my front tyres are almost worn down... Will be driving carefully until new wheels are delivered :-(
air121005
1,609
Worcestershire
We've had a good 3" thick blanket settle since 1pm!!!
Certainly glad I left them on now as I'd considered putting the summer wheels back on 3 weeks ago!
dalegolf215
UNbanned
Jun 3, 2010
1,151
Rov'rum
A couple of inches here now
I'm off out to test the winters for snow grip soon ...I shal return with either smugness or pics of an epic fail :)
Johnersh
35
Just done the same - went actively looking for hills and to see what (sensible) speed could be maintained before the grip went off.
Quite impressive really - not sure i'd have made it up one of the hills I climbed without winters... On a simple note, ost impressive was how the car stopped and pulled away from the traffic lights in the slush; basically no wheel spin. I might just be a convert to winters forever
