Ibiza MK4 Alana Headunit Wiring
PriceyFR
Stranger...
Nov 30, 2007
161
Ipswich/Belfast
I know but im guessin the 1 that says tel-mute is for the telephone muting...lol
and i think the switched plus is the ignition 1 ur lookin 4...think thats what i used when i wired up a sub and amp to my standard head unit...its just really trial and error...get ur multimeter out :)
PriceyFR
Stranger...
Nov 30, 2007
161
Ipswich/Belfast
Hope you appreciate my MS Paint efforts...
Leighrj
I notive this post is really old. I have a MK4 Tdi, fitted an aftermarket, took it out again.
Problem is I have to turn my amp off maunally everytime - which wire do I connect to turn the amp off when I turn off the ignition ?
DEAN0
Old Git
Feb 1, 2006
5,360
348
Preston - UK
Look at post 25 in this thread - you need to use pin 5 on the head unit to the remote wire on your amp for auto switch on.
Leighrj
Thanx Deano, wasnt sure what the wire is called.
Can you tell me what must I do also ?
From the radio I have inserted a hi-to-lo convertor. This convertor has 5 holes, 4 for speakers and one for ground.
2 Questions -
1. What do I put in the slot named "G" ?
2. What do i do with the remote wire ?
DEAN0
Old Git
Feb 1, 2006
5,360
348
Preston - UK
2 Questions -
1. If "G" is for ground then you need to connect "G" to terminal 8 on the head unit - best to keep a common ground for audio
2. On your amp there should be three wires + 2 phono plugs.
The three wires should be +12v, -12V(ground) and a switch(remote) wire (usually thinner than the other two) - you need to connect the switch(remote) wire to terminal 5 on the head unit
Leighrj
Theres no wire coming out of pin5 ? Its empty.
Pin 1 - 2 wires
Pin 2 - empty
Pin 3 + 4 have a wire each.
Pin 5 - empty
Pin 6 - wire
Pin 7 + 8 has a thick wire each
DEAN0
Old Git
Feb 1, 2006
5,360
348
Preston - UK
Pin 1 - 2 wires
Pin 2 - empty
Pin 5 - empty
Pin 6 - wire
If you test pin 5 with a multimeter you will find +12v when the radio is switched on.
This is the pin usually used for a powered ariel or amp switch on.
If you dont want to or cant use pin 5 - Your only other option is to find an ignition live and have the amp switch on with the ignition rather than the radio.
PS - why are you using a high level input for the amp ? - you could get a connector that fits in to the kammer 1 section of the radio - it gives you pre out for the amp and a 12v signal at pin 6 to switch on the amp.
Leighrj
Im in South Africa, explaining things to people here, OR finding things like these, are highly unlikely..
Leighrj
Okay Thnx Deano Im quickly going to check the voltagie get back to you now
Leighrj
The Diagram above shown by Pricey is switched around.
Found the +12 wire, is a small thin brown wire. Ignition on = green light on amp. Ignition off = no light on amp :)
Thanks alot Deano, glad this is sorted out now.
Only thing now is waiting for my radio code :)
Leighrj
I unplugged it earlier, not realising when plugging it back in, it is going to ask for a security code. Phoned AUDI in Pretoria, say theyll send it by tommorow.
Code isnt my Alana guide, nor on the radio. Gave them the serial and Chasis number.
Bummer.
