To further my explorations into aero effects, following on from the front floor/airdam/splitter, I thought it might be a good idea to try and give the rear end a
help by stopping the air coming in under the sides of the car with some sideskirts. These will also give something to hang a flat floor off if I eventually go down this route.
So there is a nice 20mm wide seam that runs down the underside of the sill that looks good to fasten a skirt to. Have ordered some nice nylon threaded inserts that I will bang into 8mm holes. Pics when they arrive.
So the skirt is made slightly tricky by the fact that the seam is not level - took quite a bit of measuring to get it right, and both sides were different (of course). Flat garage floor helped a LOT with this.
So tonight we have two skirt panels cut out of 3mm ABS plastic ready to go on when the inserts and fasteners arrive hopefully tomorrow.
Skirt is currently 50mm from the ground but will end up 70mm when the race wheels are on. Regs say min clearance is 40mm so well clear of this.
More soon
Ave it
Rob
