So I managed to do a couple of minor tasks on the car at the weekend. First changed the MAF for a new one from Seremotors. Had this logged (thanks Yohan!), see below:
Code:
Saturday 3 December 2011 15:40:24:62534 VCDS Version: Release 11.11.0 Data version: 20111111
1ML 906 032 A 1.8l R4/5VT 0002
Group A: 020 Group B: 120 Group C: 002
Timing Retardation Timing Retardation Timing Retardation Timing Retardation Engine Speed Torque specified Engine Torque Traction Control Engine Speed Engine Load Injection Timing Mass Air Flow
TIME Cylinder 1 Cylinder 2 Cylinder 3 Cylinder 4 TIME (G28) by ASR (actual) Status TIME (G28) Sensor (G70)
Marker STAMP °KW °KW °KW °KW STAMP /min Nm Nm STAMP /min % ms g/s
9.61 0 0 0 0 9.91 1520 436.6 64.2 ASR OFF 9.32 1920 54.1 4.76 21.22
10.52 0 0 0 0 10.82 1600 436.6 81.3 ASR OFF 10.21 1560 48.9 4.08 14.42
11.42 0 0 0 0 11.74 1680 436.6 162.6 ASR OFF 11.13 1640 83.5 8.16 30.39
12.33 0 0 0 0 12.64 1840 436.6 192.6 ASR OFF 12.02 1760 94 8.5 34.67
13.23 0 0 0 0 13.53 2040 436.6 231.1 ASR OFF 12.93 1920 106 9.86 41.97
14.15 0 0 0 0 14.45 2280 436.6 278.2 ASR OFF 13.84 2120 130.8 11.9 57.53
15.05 0 0 0 0 15.35 2560 436.6 299.6 ASR OFF 14.74 2360 160.2 14.96 80.64
15.96 0 0 0 0 16.26 2800 436.6 297.5 ASR OFF 15.66 2640 166.9 15.3 79.17
16.86 0 0 0 0 17.17 3080 436.6 299.6 ASR OFF 16.56 2920 162.4 14.62 87.5
17.77 0 0 0 0 18.07 3360 436.6 299.6 ASR OFF 17.47 3160 157.1 14.28 94.69
18.67 0 0 0 0 18.98 3600 436.6 299.6 ASR OFF 18.38 3440 157.1 13.94 102.39
19.58 0 0 0 0 19.88 3880 436.6 303.9 ASR OFF 19.28 3720 160.9 14.28 115.06
20.48 0 0 0 0 20.79 4120 436.6 303.9 ASR OFF 20.19 3960 160.2 14.28 122.86
21.4 0 0 0 0 21.69 4360 436.6 308.2 ASR OFF 21.09 4200 160.2 14.62 128.11
22.29 0 0 0 0 22.6 4600 436.6 293.2 ASR OFF 21.99 4440 158.6 14.28 134.97
23.2 0 0 0 0 23.5 4800 436.6 286.8 ASR OFF 22.9 4680 154.1 13.94 135.86
24.1 0 0 0 0 24.41 5000 436.6 299.6 ASR OFF 23.8 4880 152.6 13.94 143.5
25.01 0 0 0 0 25.31 5200 436.6 291 ASR OFF 24.71 5080 158.6 14.28 154.39
25.92 0 0 0 0 26.22 5400 436.6 286.8 ASR OFF 25.61 5280 161.7 14.62 164.69
26.82 0 0 0 0 27.12 5600 436.6 293.2 ASR OFF 26.52 5480 163.9 14.62 172.22
27.72 0 0 0 0 28.03 5760 436.6 291 ASR OFF 27.42 5640 163.2 14.62 178.31
28.64 0 0 0 0 28.93 5960 436.6 273.9 ASR OFF 28.33 5840 166.2 15.3 183.94
29.54 0 0 0 0 29.84 6080 436.6 265.4 ASR OFF 29.23 6000 160.2 15.3 184.83
30.44 0 0 0 0 30.75 6240 436.6 265.4 ASR OFF 30.14 6160 155.6 16.32 183.94
31.35 0 0 0 0 31.65 6400 436.6 244 ASR OFF 31.05 6320 154.9 17 183.33
32.25 0 0 0 0 32.56 6520 436.6 248.2 ASR OFF 31.96 6440 152.6 15.98 181.28
33.16 0 0 0 0 33.47 6640 436.6 233.3 ASR OFF 32.85 6560 142.1 13.94 176.47
34.07 0 0 0 0 34.37 6600 436.6 0 ASR OFF 33.77 6680 142.1 13.26 170.75
34.97 0 0 0 0 35.27 5600 436.6 0 ASR OFF 34.68 6520 14.3 1.7 12.92
35.87 0 0 0 0 36.18 4400 436.6 0 ASR OFF 35.57 5200 14.3 1.36 14.31
36.78 0 0 0 0 37.07 3120 436.6 0 ASR OFF 36.48 3960 12.8 0 9.64
37.68 0 0 0 0 37.98 2040 436.6 0 ASR OFF 37.38 2760 13.5 0 7.17
38.58 0 0 0 0 38.88 1240 436.6 0 ASR OFF 38.28 1720 12.8 0 4.36
39.49 0 0 0 0 39.79 1000 436.6 0 ASR OFF 39.18 1160 15.8 1.7 3.36
So 184.83 g/s peak, happy with that. Interestingly though, as on the previous lot of logs, Yohan's de-screened MAF showed a peak of 197 or so. Haven't returned the old MAF yet, am tempted to hang on to it and descreen the housing and swap my good element into it. Will do some re-reading, there were a few threads going about on this recently.
Anyway, the new MAF is reading better and has cured the correction factors I was seeing at high RPM so that's cool. Other job this weekend was changing the coilpacks. Got some of the red ones from Awesome, pics below:
I had assumed that since I'd never heard of anyone else with a late mk1 LCR getting their coilpacks changed on the current recall that my car and/or existing coilpacks weren't going to be eligible for it, so went ahead and bought these. Checked a couple of them when I took them out and they look like very early parts. I wanted to change them anyway as the car is getting remapped tomorrow and for peace of mind thought it wouldn't be a bad idea to change them.
In hindsight I suppose I should have called Seat and chanced getting them changed for free but I guess I can always ring them and if they say to bring it in then change them back to the old ones. Besides, these ones look nice
Had to bolt the N249 stuff back into place though as I couldn't be arsed finding a new home for it as this would mean digging the cable out of the coilpack loom, might do that some other day.
Revo stage 1 linear map tomorrow - can't wait
