I have a coupe of quick questions for you D.K, which sealents would you recommend and did you paint your splitter yourself? The reason I ask is mines the same colour and whatever you use brings out the silver really well.
My favourite sealent at the moment is Werkstat Acrylic Jett
It goes on really easy and leaves a nice wet finish, it's also a good product to use during the winter as the cure time is fairly short unlike waxes, and it's not affected by cold temp's.
If you want to get a really good finish it's all in the prep work, If it's not already been done you'll need to have the car clayed and machine polished by someone who knows what they are doing, this will get ride of any imperfection's in the paint plus any swirls, Swirls are a lot harder to see on silver paint, they tend to make the surface look cloudy.
Weekly routein
Wash wheels with Megs Gold Class shampoo useing Large EZ detail wheel brush
Rince body work
Wash body work useing Auto Finesse Lather shampoo, Lambs wool wash mit, DoDo juice bucket with grit guards.
Rinse with an open ended hose.
Dry using Elite Ultra Plush Deep Pile Drying Towel and Megs last touch QD to disperce the water and to lube the towel.
Clean windows with Auto Glym Fast Glass
Dry wheels, door shuts and engine bay
Job done
When I'm getting mine ready for a show or if I've got a spare day I'll do the following.
Clean all rubber's and plastic trim with APC and detailing brush.
Jet wash wheel arch's
Clean tyres useing APC, Need to source a better cleaner.
Wash wheels with Megs Gold Class shampoo useing Large EZ detail wheel brush (If their really bad I use Wolf De-ironiser first)
Apply a layer of Werkstat acrylic Prime
Then several layers of Werkstat acrylic Jett, you can apply quite a few layers.
All rubbers and plastic trim are sealed with Auto Glym Vinyl and rubber care.
Wheels are sealed with Wheel Wax.
Apply Megs endurance tyre gel,
Clean windows with Auto Glym Fast Glass.
Then I start on the engine bay
On arrival at show's
Wash the car again and dry with QD, then apply a couple more layers of sealent.
Auto Glym HD wax and DoDo Juice red Mist also work very well on siver but dont use them together.
