James' LCR - 2008cc Stroker HTA GT3071r! - Tuned @ Badger5
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
Got everything mate, the whole shooting match. It's just the other stuff hasn't arrived yet.
Going to start to strip the head down, remove cams, valves etc. then give it a good clean. Any pointers?
Jul 4, 2010
2,170
Cambs
I have only got as far as stipping mine down, dont want to rebuild it if its just going to sit about for a few months.
Make sure you use a motorbike valve spring compressor for the inlet valves as car ones are too big. I used a little magnet on the end of a rod to remove the keepers as they can be a bit of an ass and get caught up.
Easy enough job though, just take your time and keep everything in order.
Jul 4, 2010
2,170
Cambs
forget about keeping everything in order then! Im not rich enough for new lifters aswell :(
I had exactly the same thaught, but after having a good chat with Alex I have decided to leave well alone.
Its not just as simple as increasing the size of the ports, the shape is also very important.
The balance between the inlet and exhaust ports needs to be taken into concideration too. To do it propperly you need access to a flow tester.
By increasing the size of the ports but getting the shape wrong could actually slow down the airflow.
Unless you know what you are doing I would leave it to the professionals.
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
to be honest, i'm debating about gas flowing the head all together, just had a look and the casting marks are quite promenant, just don't know if i want to spend £500(ish) on head work on top of everything else.
Jul 4, 2010
2,170
Cambs
Still an extra £200+ that isnt really needed if your lifters are fine
I dont thing the gains would be worth the extra on a 3071.. Im leaving mine well alone.
Casting marks arent always a bad thing on the inlet side, as it adds turbulance to the airflow meaning a better air/fuel mix.
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Nice one mate!
Progress is coming along swiftly here with parts. Looking forward tos seeing how this one turns out for sure.
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
Stripped the cams out of the head
Going to get the head all cleaned up and ready for porting & polishing
