Adam's K03s Imperial Blue Mk3 Ibiza Cupra: car sold BUT HAVE SOME BITS LEFT OVER
ad_182_uk
242
Long Eaton, Notts
Did you get that s3 pump I said about?
Yer chap got it all fitted pumping fine, musta not connected one of the little clips to circuit board quite rite tho as fuel gauge not working.
No more lambda codes now either so ko3s stage 2 running all good. will just have to RR it one day or something but going to leave as is for now... just put winter wheels on will just be kept clean etc now.
just fuel gauge, stereo stuff and bonnet left to bug me now, maybe get round to them some day ha
Adam
ad_182_uk
242
Long Eaton, Notts
Since last post have done the following stuffs :) :)
new bosch o2 sensor (sorted all code related problems when coupled with new fuel pump)
white wheels back on for winter, made sure i waxoyl'd all the prone rust spots too!
R8 oil cap fitted and rear badge sprayed (pic below)
also went to chesterfield to JBS vag specialist and they said car is running fine so happy days :)
ad_182_uk
242
Long Eaton, Notts
SPRING CLEAN
As hopefully we have seen the last of the gritters ive been able to get the summer wheels back out and give the car a mini detail :D
a few pics....
Also managed to get some progress on the whole headunit/centre console thingy which is sorta half done now but im in no rush atm!
So, just got that to finish off and want to get 4 new Toyo T1-r's on the wheels.
Bonnet still needs a respray too but its like £200
Adam
markojay
143
Aberdeenshire
Nice car!
im looking into the Cades Eros wheel and was wandering what offset you are running? and are u using any spacers on the front?
cheers
EddyCupra
Lovely looking car there dude :D Iv got the same colour, was wondering where you got your pressed plates from!?
ad_182_uk
242
Long Eaton, Notts
Nice car!
cheers
et35 standard offset, no spacers on front so no rubbing, 15mm on the back so no rubbing either. perfect.
pressed plates off ebay a while back matey.
Adam.
ad_182_uk
242
Long Eaton, Notts
Not too much really.
Bonnet needs a respray really,
Maybe tint 3 rear windows same as wind deflectors and gitta sort stereo out.
Other than that used a proper machine polisher last week and came up amazing so just keep it looking good!
Adam.
ad_182_uk
242
Long Eaton, Notts
Like i said, finally got my hands on a DA so had a blast with that and some mezerna power finish and final finish. Finished with some PB black hole and Dodo purple haze.
Also had a bit of that 3m di-noc carbon stuff so did my door pillars in that defo a nice touch imo.
other than that car is still same as it has been... stereo still not fully sorted and still contemplating 3 rear windows light tint to match wind deflectors and a bonnet respray...
pics after using the DA (all with iphone -_-)...
Adam
