Good luck...
We have had (10) 7670's on order since September 2010. No way anyone who placed an order between July and now will get one before all the back dated orders are fill filled....
Hopefully Treadstone ordered them a long time ago, i'm sure they'll be worth the wait though, plus there not holding my project back at the moment far too much to do.
Thats not good news
Not good news at all, but if the turbo turns up this side of christmas i will be happy... still got quite a bit of fabricating to do, plus car needs painting and all the bodywork sorting, so i won't be getting bored for a while
Just a small update before i go away on holiday to spain for a week, did a couple of hours on the car today.
I put the front half of the rollcage in, lined it up best i could...the back wasn't sitting right, its almost like the dimensions are all wrong.
The front part of the cage follows the shape of the dash, after i got the front in position i had a sit in and really wasn't happy with the position of the bars, they really block visability and i think they would be a pain to live with.
So after a rethink i have decided to have the car more civilised and run the back half of the cage with doorcards and full carpets.
I removed the cage (managed to smash the windscreen in the process
) and cut the parts off that the front cage connects to.
To get the angle of the cage right i had to also cut 2" off the back legs. I will have to make a new set of plates to bolt the legs to the arches. Gonna also put a bar between the rear points to hang some harneses off.
I wanted to mount the cage further back so there was plenty of room for the seats plus it looks a bit better.
I started to make the rollcage mounts, i used the mounts that were designed for the front.
Had to grind in a radius and fit them to the corners, i then tacked them in place and marked the hole positions.
Drilled and tapped the holes so there would be studs sticking through, i TIG welded the heads of the bolts to stop them from turning and welded up the seams -
Pics of the blocks tacked in place -
Took some measurments and the cage is sitting nice and square in the back.
Anyhow got a full week on the car when i get back from spain so should get plenty done.
Ta tar.
