I certainly would not want to chuck it about spaced to that extent like I chuck mine about!
Spacers in my mind are a stance and show thing, if you look at the kind of work that goes into BTCC and race cars to widen the track its a bit more than spacers, it's done with longer wishbones and engineered hub carriers that position the hub out further pretty much everything is custom, and not a spacer in sight, why? Because the loadings on the bearing would cause failure! And it's not proper! Sorry I can't see this working, prove me wrong!
Sent from my IPhone when I should be doing Work!!
25mm spacers?? Will you not need wider than that?
Firstly don't take it the wrong way, your on a forum and your going to get positive and negative comments that's what it's about, I just don't see the point in wider arches without filling them out properly, seems silly.
I'm not taking the piss mate just raising my opinion, whether you listen or care I'm not fussed! no offence meant by any of it dude!
Are you doing the rear arches too?
Looking good Leon
Looks superb, be even better with the finishing touches, i like that!
Thanks george, fancy helping me fitting some coilovers so it looks even better
