Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
Still ko3 at the moment. Not checked actuator, problem has been since rocker came off few weeks ago and last week it got redone to retrace my tracks and still crap. Still loud induction noise rather slow but boost gauge is still saying 20psi. Put new silicon on bypass and it's still the same. And it's been vag com'd that said it was vac or boost, boost pipes have Been checked
Why dont you just bypass the n249? eliminates the problem then.. Are you sure you connected all the charge pipes nice and tight.. Id boost leak check it aswell.
I dont think the actuator would be the problem as you havent touched it..
the only things you would of disconnected removing the rocker cover is n249, chargepipe, and coils
Coil pack are new mate, peachy has solved the problem. The vac pipes are wrong so will sort this tomorrow since it's raining the now :/ thanks for your help
