thanks for that Bill, interesting stuff. I had missed that build, some nice fab work on the mani there ! is there no end to the Badgers ability !!
respect for all the work / research you have been putting into these hybrids. I have had numerous issues, and been close to binning it so many times.
3 turbos later (1x JBS / 2x CRT), I think I have had my fair share of bad luck. All turbo related faults have been replaced under warrenty, but does not cover the pain/cost of keep removing and refitting
Just waiting to decide what to do about the ABS pump before putting car back together. Not enough clearance for the 3" tip, undecided on moving it like Roly has done on his Mk2 or just binning it altogether.
Hi Morgan, i have sent you a message about the turbo issues. How are you getting on with the manifold / hybrid setup - done any further mapping ?
bit of a **** to fit then
looks lovely now its on
How did you manage to do up the top DP to turbo nut, and the mani to turbo bolts on the DP side??
No really progressed any with finalising the mapping, but hope to make sometime in the next week or so to get it completed.
Looking good, I noticed you have a VVT tensioner too, what are you doing about this, I assume you're staying with the OEM narrowband ECU?
I've used Aerotight nuts on the last mani I fitted, worked a treat
wow..... cant wait to se more loving the build.
After some hunting around managed to source a cast alloy water take off with just an outlet for the radiator and boss for the temperature sensor. Without the takeoff for the heater and one below it for the oil cooler it saves some space just where it is needed.
Another interesting little part for the build. Not an item usually found on a road car !
Where did you find that elbow from?
badgerwagen and a few conversion builds would benefit from this too
could you let me know where you found this?
FPA car or New F2 car - Mounttune?
many thanks
How have I completely missed this thread! I thaught I was the only one
looking good mate , i'm also now getting a forge actuator of danny , but have no idea how they work will need to read up on it
Hi James, hope your build is going well, just gave your RR a read looking really good mate ! Sorry I went hybrid with a JBS05 back in 08, just dont get on SCN much to update my thread.
Hi Joe, did look into changing back when it had Custom Code 3 mapping done but ended up staying narrowband, the VVT is just left disconnected.
Im not sure on the plan when it gets set up this time round, I have a complete Seat Sport loom for the engine which can easily be adapted to a standalone management system or may just stay with the narrowband. Something to discuss with whoever ends up setting it up again.
Greg, I'm looking into a wideband conversion in my RR so that may also be something to look into. I will resistor out the VVT but it may be something I add at a later date. Not sure if it's benefical enough to warrant buying another tensioner though.
