mk3 Ibiza Cupra R Hybrid K04, Supercopa BAM engine, TSR Manifold. ** Breaking**
GregP
Ibiza Cupra R JBS05
Aug 19, 2007
146
Essex
sorry for not posting and lack of updates !
Got car back from JBS, big thanks to all the guys for sorting the car out and getting it set up properly. Top work !
Running CC3 1.5bar map and made 303bhp on JBS rollers. Told it could run more boost with a better manifold. Still waiting for someone to make one...... !
Relocated battery to the boot to fit water injection and made new fuse box with ETA circuit breakers. Cheers Nick for sorting the kit out, finally got round to using it !
GregP
Ibiza Cupra R JBS05
Aug 19, 2007
146
Essex
Thanks for your comments, its been a right mission, but its been worth it. Turbo is hybrid K04-023 from JBS.
Going to change suspension to new coilover setup and fit new diff, then leave it alone and get out for some track action later in the year.
Cars current spec:
ENGINE
Seat Sport Leon BAM Engine 2007 spec (Built by Swindon Racing Engines)
Seat Sport Leon Baffled Sump
JBS05 Hybrid K04-023 Turbo
Seat Sport Leon Injectors /4 Bar Fuel Pressure Regulator / 4 Bar Lift pump
Seat Sport Leon Fuel Swirl Pot / Bosch Secondary Fuel Pump
Samco TIP
RamAir CAI
Seat Sport Leon Silicone boost pipes
Seat Sport Leon Alloy Boost Pipes
Forge FMIC
3” Custom Stainless Downpipe, Fibreglass heat wrapped
Jetex Stainless steel decat exhaust system
Forge oil catch tank with sump return
Viper performance black silicone reinforced coolant hoses
Aeroquip stainless steel fuel / oil hose
Vibra - technics Fast Road Front/Rear engine /Gearbox Mountings
Sachs / JBS Clutch Kit with Lightened / balanced G60 Flywheel
Custom Code / JBS phase 3 Software
Snow Performance Stage 3 water injection system
Seat Sport Mk4 Ibiza GrpN Setrab Oil Cooler + Hoses
Forge Strut caps, Coolant cap
SUSPENSION
Race Spec 2 way Spax Coilover Dampers / Adjustable Top Mounts / Eibach S2000 Spec Springs
Modified Eibach Front and Rear Antiroll bars - Modified to Spherical Bearings / Drop Links
Seat Sport Momo Front Upper Strut Brace
OMP Front Lower Strut Brace
Sparco Rear Strut Brace
Eibach Rear 15mm Hubcentric Spacers
Polybush kit Front / Rear
BRAKES
Front Brembo 4 Pot Calipers
AP Racing Front 305mm 2 Piece Discs / BG Developments Alloy Bells
Rear MK1 LCR Calipers
AP Racing Rear 255mm 2 Piece Discs / BG Developments Alloy Bells
Ferodo pads Front / Rear
Goodridge Braided Hoses Front / Rear
WHEELS / TYRES
Seat Sport OZ Racing 7.0x16 – Toyo R888 - Track Wheels
Seat Sport Speedline Corse 7.0x16 – Goodyear Eagle F1 - Road Wheels
INTERIOR
Sparco EVO Carbon Bucket Seats
Sparco Suede ‘Ring’ Steering Wheel
Sabelt four point harnesses
Custom Cages 6 Point Roll Cage (Rockingham)
Nomad Racing Pillar Gauge pod, SPA designs Boost Gauge
Lifeline manual fire extinguisher system
Red Top 25 battery
EXTERIOR
Lite Tuned Carbon Fibre Bonnet
Leon Cupra R Front Splitter
Stubby Drivers Side Mirror
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
So nice to see a car being saved from going to scrap heap heaven and even better when its turned into this beast. I WANT ONE OF THOSE ENGINES.....NOW! Great car mate ane well done on all the hard effort! :clap:
GregP
Ibiza Cupra R JBS05
Aug 19, 2007
146
Essex
Hi Nick, yes still got the Cupra R. Its only done about 500 miles in the last year as it has been off the road and garaged up for various reasons. (long story!) :cry:
Done a few more bits to it while it has been off the road, fitted the coilover suspension and changed all the bushes etc. Completely stripped the inner wheel arches and underside and got repainted so looks like new again.
On the interior side, done a bit more weight removal, but not too extreme, removed speakers and stereo and made a new blank dash panel instead. Removed sound proofing, but kept the carpet as didnt want it too noisy.
Got a few other bits waiting to get fitted up for the summer -
Front AP Racing two piece 305mm discs
Rear LCR calipers and AP Racing two piece 255mm discs.
Seat Sport MK1 Leon Supercopa fuel swirl pot and pump
I am also going to finish refurbing the set of OZ alloys and get them fitted back on again.
Hopefully get her sorted out and cleaned up again soon, as covered in dust ! so can then post some updated / better pictures up.
JordyGTI
Car looks awesome Greg. Can you post up your email address or message me it, need to contact you about some things, won't let me message you.
GregP
Ibiza Cupra R JBS05
Aug 19, 2007
146
Essex
Well I have not updated for a long while, car has done very few miles and only been out occasionaly in the past 12 months, so thought it was time to start getting back on with the project and ready for some track days.
As there has been some recent developments with mods for extracting power from the K04 setup, i have decided to carry on down this route and see what power can be achieved.
The new TSR Tubular manifold has turned up. It has had good results on the test vehicle, and if nothing else it looks the business :)
One of the turbo bolts will require a stud and a nut, as there is no way of getting to it. Also the manifold stud on number 2 runner looks like it going to be hard to reach. TSR advised easier to take the head off or the engine out. I have not decided what the plan of action is yet, am going to send off to Zircotec for ceramic coating and have a think about it !
Also couldnt miss out on the famous Badger 5 3" tip modification, which has also had excellent results, so got one in with a new Filter.
Im hoping these mods and a new map will gain a few extra bhp :)
