Cupra is ready. I just came from the garage.
Things that i did:
Quaife LSD
Kevlar/Ceramic Clutch
High Clamp Pressure Plate
Port matched exhaust manifold
Port matched exhaust housing
Forge WG
Turbo and manifold are machined to run without gasket
First thing that i noticed is that i had an exhaust leak that is gone.
When i drove the car i felt that has gained some low end torque.
Boost pressure is 1bar with profec closed.
Clutch is pretty strong and the pressure plate needs more force, which might be tiring for everyday use.
Now some Quaife
review, even that i need new tyres, wheelspin is reduced!
No more one side wheelspin, car spins both wheels equally, so equally that goes completely straight!!!
I cant wait to test it with semi slicks in corners.
Camshaft (and more...) will be fitted in September as the garage owner went for vacation...
