Replacing some of the smaller engine hoses, help please (pic included)?
itfben
DsignVinyl.com
Oct 24, 2009
2,000
nr. Tunbridge Wells
I suppose the Mikalor might be alright. it was just a thought/experience with one of the clips that was on the oem pipes but they didnt stick up thes wer flush/curved with the clips so pinching them together to get it loose enough to get the pipe of was a biatch. if the external diamter of my 8mm vacuum pipe is 12mm should i get 12mm clips or 11mm be a tight bite?
8bit
3,401
Aberdeen
If it's just for the small ones then just so long as you can approach them straight on it won't be an issue. The Mikalor ones look like the ones I have on the car as standard, I've managed with them fine. In fact, I might just order a bunch of those myself :)
EDIT - just saw your other post. Do the Mikalor ones give a range that they can do, like jubilees say (for example) 8mm - 12mm?
itfben
DsignVinyl.com
Oct 24, 2009
2,000
nr. Tunbridge Wells
they seem to come in 8mm 9mm 10mm 11mm 12mm etc
Ronin225
4,652
22
Worcester
Shouldn't really use jubilees/mikalor clamps on the vacuum pipe as it is not reinforced and will cut into the material
Cable ties are very strong and do the job better than the spring clips will at a fraction of the cost
itfben
DsignVinyl.com
Oct 24, 2009
2,000
nr. Tunbridge Wells
ok lol they are currently being held on with the oem clips with are just a bit tatty thought the silver/metal of soem fresh clips wold smarter things up.
8bit
3,401
Aberdeen
Mikalor is a serious over kill for them hoses.
When I was saying "Mikalor" clips I meant these ones that itfben found (note that's the brand name, not the type):
MOROalTT
180
USA
they look like OEM ones after I soak them and strip the black off......:lol::lol:
I know not funny........ :D
L8R.........[B)]
