Please excuse the poor description I am about to give.
Howcome in all the photos i have see the inlet on the front of the engine where the throttle body is points to the right hand side of the car (towards the battery cover) but on my 04 T cupra it points to the left (towards the coolant bottle)
Is there a reason for it being the other way round? the SMIc is under the water bottle, do the pictures on this thread all have FMIC's?
how'd you get this metal clip off near the engine cover?
just about to get round to changing this pipe but it went too dark, wasnt sire how to get it off anyway
Did you manage to change it
you have a cupra and i have a cupra r. different intercooler setup between the two models.
also why did i get 4mm tubing, lol i dont remember? so far everything has been 8mm, was it just for the dv?
An old pic but you can see the larger ones are 8mm
They are
1. Top of throttle body to check valve
2 Check valve to solid pipe against bulkhead
3. N75 to port on charge pipe next to DV take off ( blanked off on mine)
4. Carbon canister to hardpipes aginst bulkhead
5. Expansion tank to hardpipes against bulkhead (coolant)
6. N75 to actuator but needs to have a reducer down to 5/6mm for actuator fitment
4mm ones are:
1. Under inlet manifold to FPR
2. Under inlet manifold to N249
3. N249 to top of DV
4. Boost gauge piping (FPR is adviseable place to tee for source)
Im trying to work out some cheap mods to do, and thought of replacing the following hoses in the engine bay. Mainly the ones labelled below (thanks rsmith for the donor picture , engine bay looks sweet mate!):
They all look around the same thickness, except for maybe #3
- Where can I get the correct sized hose from?
- Will I need new jubilee clips to attach them?
- Will coolant and oil piss out when I try and change them over?
Heres what my engine bay looks like currently:
Going to black all the plastics soon too.
Thanks guys
