You know you have a
Mk2 Ibiza when
You spend ages trying to fix something, and logically it should work, but in the end it doesn't improve anything.
The seatbelts don't retract properly anymore... So I go take off the rear interior panels... Finding out there's a steel part which presses the seatbelt into the B-pillar frame, which apparantly gives it so much drag it won't retract... Ok, so I take the steel part off and seatbelt retracts nicely, still a bit slow, but oh well. I hen spent ages trying to bend the steel part out a bit so the seatbelt won't rub that much... Doesn't work as the steel is too hard. Oh well, take the whole steel thing off you think..
Ok so, with that off it works fine again. Then proceed to put the interior panels back on, thinking it's fine as the belt hardly touches the interior panel.... Guess what? Still doesn't work.
These cars are REALLY stubborn!
