You Know You have a mk2 Ibiza When........
scalpersnow86
You know you have a mk2 when...
even your car wants to give up smoking by letting you hit your hand ever time you change gear!
or
When it decideds weather your aloud to use first gear or not
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
you know you have a mk2 when the passenger side wheel bearing goes 2 times in 2 months
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
you decide almost a year after the MOT to sort the advisories, oh why did they make one rear brake line go between the exhaust heat shield an the car...... All done now though.
Terra78
Bucikin, Jerkin and doin my bloody head in
Any help on this anyone? My Ibiza 2.0 16v GTI '97 won't stop Bucking. Had a Diagnostic done, results were as follows: MAP Sensor - Signal Missing - Intermittent; Air Inlet temperature sensor - Short circuit to positive or open circuit - Intermittent; Throttle potentiometer - Short circuit to ground or open circuit - Intermittent.
High Idles around 1200 rpm then shoots up to 2000 rpm up and down constantly.
Surely it can't be all these sensors faulty? [:@]
Terra78
...your girl looks at you like she wants something and says, do you think we should get a new car? :think:
Mythbuster
352
Made, The Netherlands
You know you have a Mk2 Ibiza when....
The side is covered in grey primer and everyone looks at the side of your car like "What the hell has happened to that piece of poo car?"... ... Plus the engine is sounding funny if the music is off(otherwise it's fine.... No really! :D)...
And you still look at them like "I drive the best car in the world"... Just because that's the truth. For serious.
EDIT: I also came up with a name for mine... Lisa! :D
