Yea might have a go at getting it fixed up a bit, whats the almost easy fix for the rust though?
Cut the piece out and weld a new plate in, then spray it silver yourself... I know you have to weld for that, but I'm pretty sure you know someone who can weld(I know 4 and I'm not even into that stuff)... So it's kind of easy to DIY...
Ofcourse, it won't look as good as if you did it professionally but it will still look loads better...
You could also fill it up I guess, but would need looaaads of filler and probably wouldn't hold properly...
@Brummy: Fair enough I guess... I don't really like the big wheels on that Mk4... Btw, it looks like the door tops have a different color aswell?! *facepalms* Doesn't look right that...
