I bought a multi key "brick" to to this.. it is a casting about cube 40mm and has different lugs on each face plus a 3/8" drive socket in each face. Anyway had to file it to fit the Seat and then use a G clamp to hold it in contact.. then slowly twist it in with screwdriver while keeping pressure on with G clamp. Worked and cheaper than a proper wind back tool.. but a lot of a fiddle.. For the skinflints out there![]()
I just want to check - have you undone the brake fluid top-up cap?
If you haven't you may be trying to compress the brake fluid as you try to wind the piston back.
If so, be careful as you undo the topup now - you might have pressurised the system winding back both sides - you don't want brake fluid going all over the car.
Ah - now that makes a lot more sense
When I took a brake caliper off I was advised to remove the cap and put a piece of plastic under it and the screw it back on- this was obviously to block the vented cap from letting air in the top and brake fluid out the pipe where the caliper had been removed.
I had just followed some instructions I'd found and hadn't thought the reasoning through.
I'd clamped the pipe but I guess this was a belt and braces thing.
Cheers for that.
Can I ask, when using the "brick" did you move onto using a G clamp rather than a 3/8" wrench because you found you weren't getting anywhere fast without that extra oomph?
Cheers, Gav.
I fitted brick to piston, then used G clamp to hold brick to face with the rotating face of the clamp on the brick and the fixed foot on the outside face of the caliper (This takes 3 sets of hands!) Now have to use 3/8" extension bar which is 5" long as T-bar to turn brick using the holes in the side faces and only 1/4 to 1/3 turn at a time. Every second 1/3 turn I tightened the G clamp to keep the brick in good contact but slack enough to let me turn brick.
See now that seems like a total fiddle! The Laser tool is a one man job! Easy!
Since we're in skin-flint mode...
Anyone tried this Bergen Caliper Windback Tool:
http://cgi.ebay.co.uk/Bergen-Tools-...t=UK_Hand_Tools_Equipment&hash=item3cb3f252dc
Typically selling for around £15 rather than the typical £20 of the laser one
