Cheers Mike. I decided in the end to let nature run its course and dry out naturally as the weather simply hasn't been good enough for me to start gutting the car. After attacking the bulk of the leak water with towels I've found that leaving the windows open by about 5mm on dry days has helped loads. Obviously the water retained in the channels under the carpet will take longer to shift but the car is no longer the miserable experience it once was.
DubSteve
Steve, the best way of shifting the water is to put a dehumidifier in the car every night for a few nights. When I did mine, I simply dropped the rear seatbacks down, and stood the dehumidifier in the boot, trailing the electric cable out of the boot. I was gobsmacked at the sheer volume of water the thing actually shifted, but it worked a treat. No more steamy windows in mine now (well, most of the time anyway)
Mike
Got my butyl seal yesterday so i'll have a go at fitting it on Friday weather permitting.
My floors are bone dry now after I taped the window but I still get the musty smell in my car every now and again so looks like I'll need the carpets valeted as well
when i first had this problem, the seat dealer quoted £120 to remove the carpets dry and treat the inside to prevent mould. If youre gonna spend £80 on a dehumidifier, you might wanna consider it?
arrr....just found this thread.now i can sort my wet footwell out,if it ever stops raining!!!
Hi Guy's, Having picked up my car yesterday, drivers and rear carpets where soaked!! Read most of the posts about what it is, if i needed to take my seat out to dry the carpet, what would happen to the Airbag light? Or would i be better with a dehumidifier? Bioman
This should answer your question (cheers Mike). One other thing to consider is the possible need for a Throttle Body Alignment after disconnecting the battery for seat removal...
On Mike's recommendation I picked up a dehumidifier (ended up buying a B&Q 16l/day unit on sale for £99) which pulled about 500ml of water overnight. The carpets felt quite dry beforehand so that's not bad going. As a bonus the fog/reversing lights on the hatch are no longer misted up now
DubSteve
