pwmcd
Re: Mk 4 Ibiza 1.4 Stylance - door problem!
Can anyone help with the following door problem please? The front passenger door of my wife's Ibiza will not open, the car has central locking, all other doors work OK and it sounds like the passenger door motor is "moving". The door won't open using the inside door catch either!
Have been told that you can't get door panels off to check inside for the cause of the problems unless the door is open, which it obviously isn't and can't be opened using the inside catch!!
1. Is there anyway, without causing damage to remove inner door panel and metal security panel with the door still closed?
2. If not anyone have any suggestions, polite ones please, how to access the door mechanism with the door closed?
3. Anyone have a solution or similar experience of this issue? - any help much appreciated as my local (non-SEAT) garage hasn't been able to sort this problem and they are a good firm who can usually fix anything! The car is 4 years old in March 2011 and out of warranty.
Many thanks.
Patrick
Many thanks.
Patrick
