Guys!
Finally some progress.
I have a bit of a mix and match, well, rather my own "home brew" kit here now, and after a trial fitting today I think I have made it!
Heres what I have
Allard pancake replacement pipe, and the two hard pipes from EGR down to mid of engine, and the lower section of hard pipe.
SFS Aluminium hose inserts for turbo outlet and intercooler ends.
Special SFS extended turbo outlet hose
Assorted SFS bends, 45 deg and 90 deg.
Allard EGR removal kit.
This evening we set about removing all of the old gear and trial fitting the new stuff, so far my only issue is my upper bracket to the left of the engine being broken (being welded tomorrow) and the allard pancake replacement being too long, which we have now sorted, and I am having the end swaged tomorrow morning locally.
The brackets that hold the boost pipes to the engine appear to be fine, some minor fettling will be required, but thats to be expected.
The only other
problem is that the allard boost pipe has a rather large hole for the MAP sensor, somwhere in teh region of 19mm, and my map sensor is alot smaller, can anyone shed any light here??
Pics will be up later in the week after I have had all other prep work done, and I have access to my mates ramp again.
Scott
