Leon Cupra project “The Black Mamba” 800++ HP 1.8t build(engine assembly page 9)
crying_boy
Newbie
Jan 8, 2006
143
Portugal
OK some progress
First of all ill start with a BBK project I have been working on for the rear of the car to fix the bias of the front braking power
Not that it’s too bad but considering I’m running a set of 365mm 8 pot Brembo's in front I though it couldn’t heart to upgrade the rear
So hear you go, I got a set of custom brackets cut up to fit a set of Cayenne 4 pot Brembo calipers and a set of Brembo parking brake calipers
Discs are 312mm just waiting for a set of braded lines specially made for the swap that are on the way and the set of Brembo parking calipers
I am going to get the cayenne calipers powder coated in black to match the front brakes as well before I get them fitted
Brakets
Cayenne Brembo 4 pot caliper
And now to real progress a few parts came in for the Exhaust system I’m working on so next week I’m going to get it build
Custom made 3” all the way with all V-band connections and all Stainless Steel 304
You can see the Stainless Steel 304 V-bands turbo flange and CO2 bungs and also one set of 4” V-band to conect the two parts of the DP and two 4” to 3” transaction that are intended for the 4” DP I will be building when I finally get the intended turbo
I will be back next week with pics from the exhaust manufacturing and install
I'm dying to see how it goes with these brakes at the rear. :blink:
and a video to hear the sound of the exhaust line?
When will it be done?
:-o[B)]
Talx
99
Well if anyone is interested the mounts will cost $250
Rear Porsche Cayenne Brembo calipers cost me $250
Rear Jaguar S Type R $250
Special braded lines for the swap $110
312mm Discs $140
Total cost for me was $1000
Not bad considering the only full kit sold on the market by MBT- Engineering quoted me 3128 EURO!!! For a rear brake setup with Porsche boxer rear calipers So that’s almost 4 times the price!!! :wtf:
If anyone is interested you can get the mounts from me :D
the rest of the parts are obtainable at a salvage yard for more or less the price which I paid
Talx
99
Ok I finished the 3” exhaust system this week it wasn’t easy to get this thing snug under the car without rattling and going over the rear sub frame because of the Haldex but I think it came out ok
Also looks like I’m going to need to do some work on the fire wall and tunnel to get a 4” DP threw without hitting anything
Going to need some hard motor mounts for sure
Talx
99
Next time I hope I will have some interesting updates on the motor build
Starting the semester next week so no more updates for the next 4
Talx
99
thanks
a few small updates most of the rear brake kit parts came in only waiting for the rear Porsche cayenne calipers which are sitting with my uncle in England waiting for someone to pick them up for me
I got the mounts and calipers sand blasted and ready for powder coating on Sunday
Talx
99
Took the brake calipers apart in the ned powder coated them and put them back together
Actually wasn’t as hard as I thought it would be
Also got AN 10 and AN6 fitting welded to the Fuel rail and got it powder coated as well
I got an oil breather adapter and welded a AN 12 fitting to it for the new catch can/oil breather system
Talx
99
nope its not FWD its AWD haldex ;)
small update on fittings
just because black fittings are so sexy doesn't matter if it's on your car ore your girl [B)]
ok from left to right this is what's going into my project
Row 1-3: fuel delivery from 2 X 044 bosche to fuel rail
AN -8 to M18x1.5 Metric Adapter X2
044 bosche fuel pump (coming soon)
Speedflow -AN8 BOSCH Fuel Pump Outlet Check Valve 044 X2
AN -8 90 DEGREE X2
AN -8 STRAIGHT X2
Aeromotive billet Fuel Y- block 10-an 2 an 8
AN -10 STRAIGHT
(fuel filter coming soon)
AN -10 STRAIGHT X2
AN -10 90 DEGREE
modified ATP Fuel Rail with 10 -AN inlet to 6 -AN outlet
Row 4-5: fuel return to fuel pressure regulator to surge tank
AN -6 180 DEGREE
AN -6 STRAIGHT
Aeromotive ORB-10 / AN -06 AN MALE FLARE REDUCER 15609
(Aeromotive marine injection bypass regulator 13114 coming soon)
AN -10 (AN10 AN 10) Hex Head Port Plug with Oring
Aeromotive ORB-6 / AN-06 male Flare Fitting 15606
AN -6 90 DEGREE
AN -6 STRAIGHT
AN -6 STRAIGHT Push-On Fuel Hose Fitting X2 (for surge tank feed and return)
Row 6: oil feed line
1.8t oil feed to AN -4 adapter
AN -4 90 Degree
AN -4 90 Degree
AN -4 to NPT restrictor (no need for this now with my new turbo on its way)
Row 7: oil return line
oil return flange
AN -10 to 1/2" NPT Straight Adapter
AN -10 45 DEGREE X2
lower Adapter flange 1.8T oil pan
Row 8: water line inlet
AN -6 to AN6 Straight Flare Union Adapter
AN -6 STRAIGHT
AN -6 90 DEGREE
AN -6 to 1/4" NPT Straight Adapter
14mm bango to 1/4 NPT
Row 9: water line outlet
AN -6 90 DEGREE
AN -6 STRAIGHT
Row 10:
AN -12 1.8T breather adapter
AN -12 (AN12 AN 12) Male Aluminium Weld On Fitting (for custom catch can and breather setup coming soon)
Row 11: surge tank fittings
AN -6 (AN6 AN 06) Male Aluminium Weld On Fitting(for custom surge tank coming soon)
more updates coming soon
Talx
99
its called the Seat Leon Cupra 4 this model was sold all around Europe including the UK
Injector Dynamics 1000cc Ev14 high imp injectors are in
flow tested and matched :)
Talx
99
ok some parts came in this week
Aeromotive A1000 marine regulator stealth black
2X Bosch 044 fuel pump
2.0 TFSI 92.8mm forged crankshaft directly from VW
more updates on the work soon
Talx
99
sounds good to me [B)]
we do deserve the recognition for this project for all the time and parts we are putting into it
Talx
99
got some parts back from powder coating today: oil filter housing motor mount block and rear calipers
I also striped and dismantled the rear Porsche Brembo calipers its actually quite a simple job to do just stick an air nozzle into the oil pipe entrance and give it some air pressure and the pistons pop out easily then with a small screw driver leaver out the dost boots and oil seals if you don't damage them when removing them they are reusable if you do damage them they aren't too expensive its about 30 Euro a set for each caliper
ok pictures as usual
coming up next: sure tank project I have been working on and I start to build the motor [B)]
