Hi
I'm Michel from Sweden I have an Seat Leon Cupra that i bought new 2½ years ago.
It wasn't supposed to be a project car i promised myself and my girlfriend.
She was tired of me taking to much time with my old car already...
So i promised her that i wont do anything on this car....
But that didn't last for long
Maybe some one wants to see the car?
Started like this 2 years ago brand new:
Ended something like well check the thread
I will try to put pictures of many things i done to the car untill today.
please check the pictures and say what you think?
Lets start,
Day 2 with the car:
I promised My girlfriend that that will be the only thing i will uppgrade on it...
Second week or so with the car :
I talked her in to it that this moods was neccesary for the car so it will not break ...
hehe
Much pictures on all of the mods later in the thread please say what you like or dont like.
Or if you have any ideas that could be done.
Adding a Spec list of the engine and many parts that is mounted untill today...
Parts come from
www.JE-Design.de
www.awesome-gti.co.uk
www.sorensen-performance.com/shop
Software from www.vtech.se
Stereo from www.mds.se / www.mdssweden.com
Carbon from SVK Customs www.svkcustoms.com
Engine: 2,0 TSI
Cylinder/valvesl : 4 cyl 16v
Cm3 : 1984cm3
Exhaust: 3" fullflow exhaust 100cpi Racecatt
Fuelsystem : Direct Injection, Turbo, double Intercoolers, water/meth
Fuel : 98 / 99 +
alternator : 140A
Battery : Optima YT42 x 2
fluids used in the car:
Red Line: Extreme Street Performance in engine 15w50
Red Line: Heavy Shockproof gear oil i in gearbox
Red Line: WaterWetter in coling system
Motul RBF600 in brake/clutch system
Spec on engine gearbox and surroundings:
Stress drilled / Honed 2,0 Tfsi AXX block
Scat H Rods
JE-Pistons
ACL Calico Coated Race Main Bearings
ACL Calico Coated Race Rod Bearings
ARP rod Bolts
ARP Head Studs
ARP Main Studs
ARP Crank Damper Bolts
FluidDampr, Pulley
APR TFSI Fuelpump
RS4 Injectors
RS4 fuelreturn valve
Devils Own Water/meth injection
Forge twintercooler (fmic) togheter with OEM Audi S3 Intercooler
Forge Red Silikon hoses to IC, Water and DV
Forge Vacum DV
Audi R8 Oilcap
VF-Engineering:
Enginemount in Polyeretan
Gearbox mount in Polyeretan
Powerflex Dogboune rear engine mount
Powerflex to to front engine mount
3" fullflow exhaust,
3" Downpipe V-Band to 100 Cpi FIA-cert Racecat or decat/Testpipe for racetrack or events.
3" JE-Design end muffler with 4x90mm
Neuspeed P.Flo : Modified to K04
Neuspeed CAI Extension
BSH High flow IC Pipe with 2 Meth bungles
Neuspeed Hi-Flow Turbo Discharge : Modified to K04
Neuspeed Carbon Engine cover
Head is planed, tested and upgraded with a
complete set of Ferrea Race valve train
BSH Race Catch Tank
OEM Plastic intake is sligtly modified with remowed flaps etc.
6speed gearbox,
Quaife differential
ARP Ring Gear Bolts
Southbend stage 5 Chryo treated clutchkit=
Singlemass flywheel
6 pucked sinter
Custom reinforced pressureplate
ARP Heavy Duty Flywheel Bolts
Forge Short Shift
Forge Short Sideshifter
42draft Design Alu / copper bushes
WOT Box With adjustable Launchcontrol and WOT
Turbosmart Eboost Street
Chassie:
Fram :
KW V3 Coilovers
KW adjustable Antiroolbars
Whiteline Anti Lift Kit
All bushes in front uppgraded to Powerflex
K-Sport adjustable Endlinks
Bak :
KW V3 Coilovers
Nuespeed Reinforced endlinks
All bushes in Rear uppgraded to Powerflex
Brakes Front:
Lamborghini Gallardo 8 Piston Calipers
RS6+ Competition discs 365x34mm
HEL , custom SS braided hoses.
Ferodo DS2500
Rear :
VW R32 brake caliper
R32 discs 310x22mm
HEL SS braided hoses
Ferodo DS2500
Rims:
Summer:
HRE P40s 19x8,5 ET35 glossblack
Pirelli P-Zero 235/35-19"
Vinter:
OZ-Racing Ultraleggera Matteblack 19x8,5 ET35
Pirelli Winter SottoZero Series II
235/35 -19"
OZ-Racing Superturismo 18x8
Pirelli Trueno
Inside:
Partly painted parts in cars color..
i have some gauges to keep track of what is happening with the car.
on steering whel i have in a modified MK5 Pod
Turbo pressure
The other ones is in a custom made A pilow pod in original fabric.
Wideband Lambda
Oil pressure
Oil Temp
Volt
ICE
Pioneer AVIC-F30BT Multimedia/Navigation unit
Rebuilded front doors with
MDS Dynamic DC6 MkII kits 1 pair per doorside
Amps to them
2pc MDS T3 A/B Fullfrekvens Hi-Fi Monoblock 1x800wrms per side.
Subwoofer enclosure is build´t to be easy to take out when needed.
2pc MDS DS1214- 12x14" subwoofer
amp for them is MDS T5 Monoblock 1750wrms in 1ohm
Double Optima Yellow topp "YT42" Batteries
For security i have this alarmsystem.
Cargard T70C with all options.
GSM/SMS Modul, GPS Modul, levelsensor, remote start/ and stop, Extra hidden battery only for alarm system, 2 extra sirens 3 in total.
And also have separate BJT activ realtime GPS tracking etc.
Styling:
JE-Design Bodykit,
JE Design Widebodykit,
(Modified to be as i want to and so nobody has the same.)
JE-Design Sport grill
JE-Design rear spoiler
(Modified with Carbon vingplane)
Carbon Hood, Both innerframe and outside is 100 Carbon =3,5kg
(made in moulds from my OEM hood and then glued togheter)
Aerocatch Locks
roof
Carbon Diffuser
Partly Carbon on front
Carbon eyebrows
Carbon B och C
(All carbon is genuine and real no folio)
MDS Lightning Division LED/RGB under the car.
(Only for shows!)
all windows around the car is tinted and even the front headlights
half beam Xenon D1S 35w 6000K
Fullbeam 55w Xenon 6000k
extra lights 35w xenon 6000k
Parking lights CanLed 6000k
Dectane Autocoutore, rear lamps with LED & Fiber
This is the list of things already mounted on the car and so..
I have a bunch of things that will be mounteed soon
4x4 conversion Big turbo etc..
Seat Leon Cupra Awd 4x4 4 motion Swap Conversion 2.0t fsi 2.0tfsi widebody JE design Carbon BBk HRE GTX3071R Vtech Pirelli
Lets start,
Day 2 with the car:
hehe
Parts come from
www.JE-Design.de
Engine: 2,0 TSI
Cm3 : 1984cm3
Fuel : 98 / 99 +
alternator : 140A
Scat H Rods
JE-Pistons
ARP rod Bolts
ARP Head Studs
ARP Main Studs
FluidDampr, Pulley
APR TFSI Fuelpump
RS4 Injectors
Forge Vacum DV
Audi R8 Oilcap
VF-Engineering:
BSH Race Catch Tank
6speed gearbox,
Quaife differential
ARP Ring Gear Bolts
Singlemass flywheel
6 pucked sinter
Forge Short Shift
Chassie:
Fram :
KW V3 Coilovers
Bak :
KW V3 Coilovers
Brakes Front:
Ferodo DS2500
Rear :
R32 discs 310x22mm
Ferodo DS2500
Rims:
Summer:
Vinter:
235/35 -19"
Pirelli Trueno
Inside:
Turbo pressure
Wideband Lambda
Oil pressure
Oil Temp
Volt
ICE
Amps to them
Styling:
JE-Design Bodykit,
Aerocatch Locks
roof
Carbon Diffuser
Carbon eyebrows
Carbon B och C
(Only for shows!)
