Almost went down the cone route for my Leon FR but after reading this I think I will order a panel filter.
sorry to sound stoopid! what do you mean by smoothing the airbox?
cheers Paul D
Open cone filters if placed in the engine bay will give more noise but you will loose bhp as the cone filter will suck in hot air from the engine bay. Hot air is less dence then cold air therefore less oxygen can be sucked into the engine.
You probably haven`t heard of people drilling the airbox as most people stopped doing something as stupid as that 10 + years ago.
An open cone will be more than 1-2 degress hotter, ive seen various open cone arrangments fitted on various cars and an open cone next to the engine allways looses power, enclosed kits are poor for gains due to the fact that the box isnt big enough.they give slight gains but not much.
The best kits are either forced air or custom made, best bet on an ibiza is a panel filter with PD160 intake.
Open cones are good for noise but not much else unless there placed right, on my old car i had the induction hosing about 5 foot long with the cone in a open foglight, that isnt anywhere near the engine and proved big gains in bhp and torque, and open cone arrangment coming straight from the throttle and sitting under the bonnet lost 2bhp. A Pipercross viper on the same car lost 3bhp, theres various articles all over the internet explaining how inductions work.
Also after a certain point there isnt much point in having a big cone as the engine can only take so much air in at a time anyway, and if you want toqrue gains then you need big hosing anyway.
Sorry but that's just nonsense. Show me figures supporting what you say? Why would an open cone be hugely hotter than a plastic air box situated in the same position
I'm not quoting Internet heresy. I have the figures for a pd160 engine and an open cone flows more air than a panel filter
Even if the air was 20'degrees hotter in an open cone, the first thing that happens to it is the it gets superheated through a turbo.
If you want 100% accurate figures I can nip out and run a couple of logs
I mite try putting a cone on my TDI and see what i think, what cone do i need ? and do i have to bodge anything??
I've run a jetex and a green. Ideally you want an oilless filter. You need a 70mm neck and there's no real need to bodge anything. The green I currently run was less than £50
