I know this subject has been covered before in parts but I have decided to put together a small guide to culminate all the info I have read up on this fault
Recently I’ve been getting rough tick over and hesitation when pulling away from cold so I decided to investigate with the help of vag com.
After running a fault scan vag com threw up the below fault code even though I didn’t get any management light.
With this code I searched the ross tech wiki site. The symptoms described matched what I have been getting wiki.ross-tech.com
With a little more searching I found the vag part numbers for the sensor, O ring seal and retaining clip
Coolant Temperature Sensor “green top sensor”: 059 919 501A
O Ring Seal: N903 168 02
Retaining Clip: 032121142
It turned out that CES in Telford where I got the parts from actually supplied the O ring with the sensor. I paid £15.57 for the sensor and 41p for the clip. I got the clip just as a back up in case I broke the old clip trying to get it off
I left my car over night to make sure the coolant was cold. Dont want boiling hot water all over me.
OK the here goes lets get grafting!! For all of 10 mins lol
Take the engine cover off to reveal all the engine gubbins (I aint got a clue what it all does either).
Ive marked with the red arrow where the sensor is located.
Another pic of the location of the sensor
Notice the horse shoe shaped clip that pinches the sensor into its housing via two slits in the housing. I got a flat blade screw driver and slowly levered the clip out. I didn’t break the clip after all so I didn’t need it, but for 41p its better to be safe than sorry
With the plug still on I gave the sensor a little twist and it popped out. It was easier to get the plug off it when out of its position. Remember the old O ring will be sitting in the sensor housing so just stick you little finger in to get it out
I reattached the plug rather than trying to do it when the new sensor was in place. The sensor goes in with the arched side towards the engine and flat side towards the airbox.
Now to fit the retaining clip. It slides in to the two slits on the sensor housing. I just pushed it on with my thumb.
Another pic of the new sensor
Now reattach the engine cover.
The old sensor with its clip
You’ll be glad to hear that all the hard back breaking manual labour is over.
All there is to do now is clear the fault code in block 17 “instruments” in vagcom and then your done.
Time for the Mrs to lay on the tea and biscuits for her hard grafting man
Trust me, if I can do this job any idiot can and ive been told the stealers charge in the region of £150 for this work.
Code:
Code:
