Oil deposits under inlet manifold/low vacuum
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Been getting this but I have no split pipes.
Also on idle i am getting about 18 on vacuum where as i use to get 22
I am boosting to 10 PSI no problem though.
Been searching about and found out this valve
Is called a suction pump valve and
Check valves are used through the car's vacuum system to operate things like wastegates, brake boosters, and even boost gauges. If you're having any problems with your vacuum system these valves could be the culprit. They allow vacuum to pass one direction and not the other. A bad check valve can lead to vacuum leaks which could affect all sorts of other items.
Part number for my AUQ engine is 058133753B
Just got to order it and try it.
greesha
Leon 1.8T on steroids
Jan 6, 2009
496
Slough
YEs the little wedge thing after the first elbow coming out from first from left outlet from inlet manifold
Deleted member 43482
What would the symptoms of having a leak in the PCV system be?
Trublu07
1,334
Essex
I didn't make it that clear. Did you take the inlet mani off to change the pump and breathers? Roughly how much was it mate. I am thinking of just getting the pump and upgrading the hoses to forge ones.
