No might have missed a button out might try it later, but chances are my CCM is to early.
I can do the alarm and everything else via vag com anyway, just the windows i'll miss out on.
:cry:
i purchased a cabel from ebay, and it came with a vcds thingy ma-bob... installed the cabel driver and downloaded the czech program...
heres what im doing..
turn ignition to on (dash check lights come on)
connect cabel
start czech program
go through the stages and click on setup, input serial code and press register. this blanks the number i just put in. then i select com port 4 and test. it says interface ok.
when i click on the ok button the activate oken button is still greyed out. if i click Konfigurace jednotky it loads a bunch of codes and brings up the window, but none of the boxes are ticked and it only the exit button at the bottom is highlighted...
:cry:
help please...
Hmm what car do you have volvic?
Have you tried connecting vagcom with that cable? You can download a free version and test the cable if not. Then try again with the czech program.
I've got a 55 late fr+ diesel. If by vagcom you mean that trial Ross program, I have that and it seems to work with the cable.
I'll try again with another laptop...
ive got the program, registered it (i think?) what bit do i actually need to change to do the windows? when i click that activate windows button it just comes up with messages for me to click OK on, then goes off and does something. windows dont shut when i lock the car though.
This is what vagcom comes up with. Could my problem be the poor test result?
Anyone had the same problem?
Go into the device manager and change the baud rate for that com port
Will give that a go, thanks.
I tried on my other halfs laptop till that battery gave way, now I've just killed my sisters battery :cry:
This might sound silly, but can anyone tell me what/where the on position is? Is it just before you start the car? (with dash lights on)
I could of sworn my old car had marks telling you the positions, but the Leon doesn't have them
Vipers_Venom said:
I did this on the weekend. Worked first time! Lappy has Win 7 64Bit. Had to download some FTDI USB to Serial drivers though.
What's the FTDI USB to serial driver for? Are you using a USB Vag Com cable?
anyone around the london/hemel hempstead area that would like to do mine for me i dont have a clue when it comes to this stuff.??? beer tokens in it. :)
thanks
lee. :)
I live in Slough. If you want to come over. No problem.
If anyone else need help from the Slough area, give me a pm and I will try to help :)
Shame it doesnt work on mine unfortunately. I will have to wait for 2.0 version :<
that would be great mate been trying to find some one to do this for me for ages. so how comes it dont work on yours.??? should work on mine right.??
