gets better and better, does the it remember the last viewed gauge/reading show when you turn the back back on?
Yes it does.
You have to manually flick the toggle down to "re-awaken" it.
Next on my shopping list. Though I would like it to fit one of the middle two vents instead of the drivers side one...
Not sure which i am using tbh.BHP & Torque Calculation mode
When in the BHP gauge, hold the joystick right to toggle between the MAF method
and the ECU Torque method, the selected method is indicated by a light grey “M” or
“T” in the bottom left hand corner of the screen.
For Petrol cars the default is to use the MAF method.
For Diesel cars the default is to use the ECU Torque method.
Interesting, Isn't there any SOFTWARE that does all the reading's this does, available to be used via a VAG-COM cable, in theory it SHOULD be possible, that way you could install a small netbook / pc in the car with a bigger screen etc etc.
Awesome bit of kit though!, I think I want one
