yeah how did you do that. ross i assume you are using the same vag com 704 that we all we? I think i may have to download it again as i have no description against any of bits when using long coding.
Also noticed you can turn off the "Cold Diagnostics" on each light unit. Meaning LED's etc hopefully wouldnt flag up as bulb out warnings.
is there any way i can get electric rear windows to work on my 1p with this vag com
have manual rears at the moment
i installed the electric rear windows last time but they wouldnt work so thaught somet might need activating via vagcom
My FR (2009 pre-FL) has done this once before and I didn't have to activate the feature. I think to trigger it you need to activate the Electronic Brake Assist.Has anyone managed to enable the emergency brake light flash. I think this flashes the hazard lights when your ABS works?
How do you know all your wiring is correct? Did it come with a guide? Have you stripped the front doors to see how it's made up in there? If it is then perhaps something does need enabling. I'm revising for exams at the moment so can't look into it more for you but I'm sure one of the other guys can have a look at the different modules/Bytes/Bits to see if there is setting for windows...
46 Central Conv
Byte 1
Bit 4 (Central Locking (Rear Lid) Softtouch (direct open/no release)
09 Cent Elec
Byte 2
Bit 2
Byte 18
Bit 0-7
Byte 19
Bit 0-2
09 Cent Elec
Byte 3
Bit 3
