EIP is
Support bolt = 33 ft-lb
Mount to sub frame = 20 ft-lb
Mount to transmisson = 33 ft-lb
Guys
I used this guide, http://www.ottawa-vdubbing.com/forum...ic.php?t=13397 to do it today,
why don't you just go on an in between torque setting, they are only suggested settings, i always go a tiny bit higher, a few NM just to put my mind at ease and my car hasn't fallen to bits yet, touch wood.
Na you need to buy an INA track density DBMok dog mount fitted imense vibrations in 1st 2nd and below 2500rpm so am i right that i need to loosen off the bolts a bit as its fitted perfectly just was in a rush so used a gun to do up bolts so probaly 100nm tightened up to????????
This doesn't need to be declared.just a quick one.
Are people declaring their uprated dogbone mounts/bushed with their insurance companies?
Should I be?
Please advise.
Ta,
I now use the stock settings
Mount to subframe 20NM + a further 90 degrees
Mount to transmission 40NM + a further 90 degrees
and support bolt as above. (45 NM)
The support bolt being the horizontal bolt that holds the bushes into the dog bone?
The bolt shown below:
