Forge 007p service,
D.K
LCR 225
Oct 24, 2007
6,408
se london
I recently acquired a second hand Forge 007p DV,
Before fitting I decided to do a pressure test on it as recommended by Forge, it showed that the DV was not holding full pressure very well and some times not holding at all, So after checking Forge's site I ordered there DV service kit
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=0006&product=FMDVSK
The kit contains 3 new seal's, a packet of grease and a new piston
Now I'm sure exactly how old the DV is or if it has ever been serviced, but when I opened it up this was the state of the piston
You can see in the picture the wear marks from where the piston moves up and down but if you rub your finger over it you can feel how much it is worn, which could cause boost leaks.
For the sake of £13 and about 30 Min's work it's well worth doing
Cupra-cal
139
Penicuik
sorry going off topic a wee bit but just wondered does the 007p actually improve anything ie. throttle response or is it just more robust than the original? cheers callum
RS6
Nov 24, 2009
1,110
im getting one for mine at the end of the month from JKM seems like a good idea to get one
what is this green spring yellow spring i keep hearing about with them?
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
The spring inside the valve that controlls the piston.
Green spring for standard car/stage 1 mapped car, yellow spring for stage 1/ stage 2 mapped cars.
RS6
Nov 24, 2009
1,110
right so when you order one should i go for a yellow spring? it will be standard for a bit though
i plan a remap and intercooler at some point not far off
wayne lcr
bored of it now
Mar 5, 2009
4,548
doncaster
i thought it was green spring standed and yellow for a remapped car i wouldent like to think there was a too stronger spring in the dv that will cause damage to the turbo
RS6
Nov 24, 2009
1,110
right i'll stick to green then until it needs changing? how much is the spring if you need it changed?
