Forge 007p service,
calum001
59
EDIT: just realised that block 115 isn't available on the shareware version of vagcom but i ended up measuring blocks 002 and 003 and got a pitifully low max 184g/s reading
just about to go out and pressure test the DV and maybe try the yellow spring that i've got
Harris.
366
Essex Bruv
Servicing 007p
Guys I received my 007 rebuild kit today and it look pretty obvious to do apart from the greasing side of things. I received a packet of red stuff which looks like grease? Is this used for putting round the seals or round the actual piston or am I completely wrong?
My dump valve has no grease of anysort in it which is prob why I have boost issues.
Any help would be appreciated.
Pyro
Grease alll the rubber bits and the inside of tge DV around tge edges where the oiston will cause friction ;)
Henjo24
Can u use any grease on the 007p cuz im thinking of giving mine a quick service tommorow?
8bit
3,401
Aberdeen
It should be high-temp grease, think the stuff that Forge send out is Mobil 1 stuff. I did this recently, does help.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Really no need for yet another thread on the subject. Search. Merged with existing thread.
lock1981
341
stockton
Lol sorry just read the thread from the start. I haven't got oil cos I haven't ordered a service kit. Just the dv
Duh
Harris.
366
Essex Bruv
Actually I did search before I posted, but was located under a title I wasn't searching under.
Not the end of the word is it !
Anyway I did my 007 service today and so far so good.
