just won alloys will i be a first ?
Jun 24, 2007
967
durham
To get anything near a small arch gap the chassis and subframe will have to be touching the floor!!!!! I think a Scottish lad had some on a black Mk4 at Edition38 last year, in a dark red, not 100% sure if they were teledials though
the coilovers i have are dropped right down on the fron and adjusters out on the back . just have to see what they look like if i dont give it a go i will never no
Ash_238
236
Most 15" wheels on an Ibiza need 195/55 tyres...
Well my factory fitted ones do.
Surely with any lower profile it will throw out your speedo & effect your top speed?
Jun 24, 2007
967
durham
sure they will be fine had to do something different didnt want to end up like a sheep with every car looking the same
Jun 24, 2007
967
durham
just picked up the alloys they are immaculate hub addapters and tires to get now sourcing 165/50/15 is being a bit of a pain in the arse
knackerdecobre
Adapters and spacers?
Thats a sure fire way to have a wheel off methinks.
Erm why? If you go no Edition38 or wheelwh0res theres loads of people that will be doing this with no problems!
Jun 24, 2007
967
durham
slight prob took the wheel of just to get a idea of how much clearance i have and its touching the brakes . 15mm is going to be a very close fit on the front
Nov 24, 2007
543
Swansea
The guy at ED38 was rolling on D90's which are 16".
Check the follwoing link out to get the wheels sitting how you want. Used the link several times and its been spot on every time.
http://www.1010tires.com/WheelOffsetCalculator.asp
Jun 24, 2007
967
durham
addapters just arrived so had a test fit there is less than a mil distance betwwen the the brake and the alloy .
