Hi All,
I have seen many threads where people mention 'Heatsoak' which is causing them to lose power, particularly it seems on cars running Stg2 or higher remaps / higher performance Cupras etc.
To my limited knowledge 'Heatsoak' is caused when 'warmer' air is drawn in and causes a reduction in power beacuse;
- The colder the air the better it combusts. So if your air intake is near a source of heat (e.g. the engine) then it will be pulling in warmer air (that doesn't combust as well) than a good cold air intake.
- Hot air is less dense than cold, so in effect you get less air into the engine. Cold air you get more air per volume due to it being more dense.
So a few questions;
For those who say they suffer heatsoak is this really noticeable, ie) the Computers/sensors cut power or is it just a case of you feel reduced power on a hot day?
How is a 'heatsoak' problem reduced/eradicated?
- With my limited knowledge I would have thought a good induction kit/CAI and a better intercooler would resolve or is this not the case? (I ask as most of you who say this is a problem already have these components upgraded)
Any knowledge welcome. I ask as it is my intention over time to continue to modify
So a few questions;
