Turbo seals again
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
This annoyin, my car smoking quite abit now, alot on when i pull away, big puff of blue smoke, checked the ic pipin, they seem to be real oily, its annoyin as this is the 3rd turbo, now its doin it with ko3s now [:@]
I checked the oil return when i fitted the ko3s and sump hole (oil retunr attachemnt) didnt feel clogged.
If the oil pressure is too high can it blow the turbo seals> at what pressure can turbo seals fail on???
Big_daddy
Oct 20, 2006
3,930
Brummy
yeh i think so, it only smokes alot once its full warmed up, can smell the oil @ a stand still, at idle it starts building up, when im off boost wait ofr a few seconds on to boost a puff os moke...
The N75 lines where quite oily too..
Jan 8, 2007
2,958
Wiltshire
Out of interest are you running a catch tank and is the PCV valve still plumbed in?
Seems strange that the problem has persisted for 3 turbos. Do you have an oil pressure gauge?
Big_daddy
Oct 20, 2006
3,930
Brummy
Yes catch can fitted, with pvc valve removed too...i know man all 3 turbos doing my headin now...
No oil pressure gauge yet, but will be fitting that soon.. some next week....
Jan 8, 2007
2,958
Wiltshire
Is it catching much vapour and completely separated from the intake, i.e. vented to atmos rather than plumbed back into the TIP?
Big_daddy
Oct 20, 2006
3,930
Brummy
When i 1st fitted it, didnt catch much but caught quite abit durin the cold weather...its venting to atomosphere, the mushrrom on the intake has been removed and plumbed..
Big_daddy
Oct 20, 2006
3,930
Brummy
Mines are stem seals as confirmed...
if the rocker gasket leak..it cause the oil to seep into sparkplug housing and get burnt off..
