Update!!!
Well finally there seems to be light at the end of the dark winter tunnel.
Initially the last time I drove the car, about October last year, the alarm was going off all the time when above 15 MPH. So that day I got home, disconnected the battery and there it has sat till the other day.
When doing google checks it seemed to point toward the door mechanism.
On the LCR there is a logic system that needs the door to be confirmed to be closed before the ECU is happy to let the car progress.
Eventually I got the battery reconnected in the car, after being disconnected for 4 months it was still fully charged. No alarm went off so all looked well.
Put the key in the slot and first fire we had ignition
Went for a spin and even above 15 MPH there was no alarms and progress was good, it was great to drive her again
So not fully convinced by this ran VAG com scan again and sure enough, door mechanism sort code.....BASTID!!!!
To remove the mechanism it involves removing the door panel, which has been done as weight saving anyway, rolling down the window till the glass mounting bolts are in view through the inner panel, supporting the glass and removing these bolts and winding the window down 'a bit' more.
This allows, with removing some other bolts the locking mechanism and the window support frame to be removed.
On inspecting the inside PCB of the logic system I noticed some wetness,
problem found.
So I have ordered a new one of these for David at SereMotors of course.
For all of those who haven't spoke to David in a while he has a new number that can be gotten through BT.
So I'm just waiting for this to be delivered, unfortunately on back order.
Also just spoken to Vince of Stealth racing.
He is currently waiting for a bearing, also on back order, to complete my Autotech Wavetrac differential fitting to my spare gear box.
I was pointed toward Vince to do this job as he is thought of being the best and has a great reputation. When speaking to Bill (Badger 5) prior to sending Vince my gear box I asked him what else needs done to the O2M GB. Bill suggested that they were very good boxes but the rivet holding the selector fork was a weak point and to ask Vince to bolt this.
So Vince has bolted this and changed a bearing in the GB itself as it sounded a little bit suspect.
So once the back order bearing is delivered this will be fitted and I'll arrange for this to get shipped back up the road.
I hope to fit this to the car ASAP and get testing
I have booked my first track day of the year at Knockhill, 6th of May with
www.trackscotland.co.uk and will attend more before this if I'm home and if the car is all back together.
I still have a heap of other bits to fit to the car so busy times ahead.
